Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 83
Thread: Shock Skin V 6.0 Released
  1. #21
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I knew your background.skin dilemma would come to a close in v 6
    Looks great treetop!
  2. #22
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Indeed, we can now all use a backgroung.skin with a central BG folder thanks to you. However, in light of this RR Config Updated - Blue ZX3 post #442, we should make the changes necessary in the BG.skin code to make it use the line that is written CORRECTLY by RRConfig in rr.ini and not have to input anything manually - that should be simple, right?
  3. #23
    Jul 2005
    Motorcity
    Blog Entries
    1
    I suppose it would be as easy as changing all the $backgroundpath$ to simply $background$ in the skin file.
    This is strange because when the first thoughts of adding this to RR the variable was known as backgroundpath, and it has to be in RR somewhere because it works great!
    Ill test it out, see if it works.
  4. #24
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by blk02si View Post
    I tryed changing them and rr just locke-up so i'm going to leave well alone.
  5. #25
    Newbie wingnut75's Avatar
    Apr 2007
    Lakeland, FL
    We'll I had it working and then I did a fresh install on my cf and this is what I get. I have updated the flash and the lastest RR. I also updated the ExecTBL.ini file. I can change to DFX 3.0 and it looks right. I'am missing something just don't know what. Any help would be great. Thanks
    Why buy it if you can build it? Even if it cost twice as much to build.
  6. #26
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by wingnut75 View Post
    Maybe this Pink Ilist,,, BAD
  7. #27
    Apr 2007
    Lakeland, FL
    @Treetop - Thanks I will give a look now.
  8. #28
    Apr 2007
    Lakeland, FL
    @Treetop- Went to my display properties > settings > color quality and changed from 16bits to 32 bits and that fix it. Cool thanks for the link
  9. #29
    Jan 2007
    dundee, il
    another thing that can cause the pink ilists is if the bmp isn't big enough to cover the area it's supposed to. i ran into this in my skin, and the best way i found to overcome it is to make the ilist bmps 800x600 resolution, that solved it for me.
    david
  10. #30
    Apr 2007
    Lakeland, FL
    I see the following sel.bmp, selBK.bmp, selDL.bmp, selPL.bmp are these the one's you are referring to.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 11:08 AM
  3. Vicky Skin (v2) released
    By Valheru in forum RR Skins
    Last Post: 10-19-2007, 05:12 AM
  4. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  5. Honda skin that released with RR
    By 93blacksrv in forum RR Bug Tracker
    Last Post: 04-08-2005, 03:37 PM
