Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 83
Thread: Shock Skin V 6.0 Released
  1. #31
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Those are the bitmaps used for the iList. Each one matches the list size exactly. Ive noticed that if you scale the skin in general.ini to say 1024 x 768 the iList does not like this and will turn pink. When I was coding the iList I used the bmp method because I could not get the other way to work. Some of the lists share these bmps but here's how they are used:
    sel.bmp - Random lists like skin browser
    selBK.bmp - background.skin browser
    selDL.bmp - Directory lists
    selPL.bmp - Playlists
    I like the idea of making the bmps 800x600, then you have all the bases covered, good suggestion david.
  2. #32
    Newbie wingnut75's Avatar
    Apr 2007
    Lakeland, FL
    Thanks for the info and I will try it out later to night.
    Update: I changed the .bmp's to 800x600 and this fixed the problem. Thanks David & blk02si
    Why buy it if you can build it? Even if it cost twice as much to build.
  3. #33
    Jul 2005
    Motorcity
    Blog Entries
    1
    How is HD menu working for you guys who downloaded the skin?
  4. #34
    Apr 2007
    Lakeland, FL
    I'am trying to get the HD Signal and I'am having no luck. Here is what I have so far.
    radio_player.skin
    S01,607,98,57,28,015,352,254,035,H,01," ",015,"HDSIGNAL","Master"
    Y01,"Installs\slider_signal\slider_*.gif"
    Were the gif's are filed : $SKINPATH$\Installs\slider_signal
  5. #35
    Jul 2005
    Motorcity
    Blog Entries
    1
    Are you trying to add a slider bar for signal strength?
    I was considering doing this but all my stations come in so clear it would probably be at full signal all the time.
    Let me know if you get this to work wingnut, would be a nice addition to the HD menu.
  6. #36
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by wingnut75 View Post
    radio_player.skin
    Try this:
    Y01,"\Installs\slider_signal\slider_*.gif"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  7. #37
    Apr 2007
    Lakeland, FL
    Sal R. >> I moved the Y01 above the slider bar and it's working now. Thanks for the info.
    blk02si >> I'am still working on some more things (AM/FM) and I will post asap.
  8. #38
    Jan 2007
    beautiful. I changed my mind on the menubar
    I need to email you the FINAL release files of the wireless.
    edit: sent, ported for v6.0
    updates:
    added WORKING enable/disable wifi for PCI AND USB wifi cards
    changed to NEW wifi_man.exe and wireless.exe files
    fixed some buttons being slightly too small for the newer .pgn file
  9. #39
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hey pwntbypat
    Thank you for the comments. I did not get your newest wifi code in my email so you can resend if you get a chance.
    Your original code that you sent me was modified for v 6.0. I cleaned up the code base and the buttons/art for the shock v 6.0 release. If you have newer code def send it my way!
    Thx again for the great addition!
  10. #40
    Jul 2005
    Motorcity
    Blog Entries
    1
    What do you have cookin wingnut?
    I've been coding more since i've been 'd in. Beats watching TV
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 11:08 AM
  3. Vicky Skin (v2) released
    By Valheru in forum RR Skins
    Last Post: 10-19-2007, 05:12 AM
  4. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  5. Honda skin that released with RR
    By 93blacksrv in forum RR Bug Tracker
    Last Post: 04-08-2005, 03:37 PM
