Results 1 to 9 of 9
Thread: can any body help me
    May 2006
    hi every body
    and i'm sory about my bad english
    i use a Simplistique beta skin
    in the game.skin include many arcade games and one of them is a freecell game every body know it and the command of the button is :
    "LOAD;SOLITAIRE.skin;Solitaire;C:\WINDOWS\system32 \freecell.exe;!FreeWClass!FreeCell"
    i want from any body to explain this command and it's parameters because i wana to add another arcade game instide of freecell when i push freecell button
    my arcade game called Ticks and it's direcetion is
    D:\Program Files\Tricks\TRICKS.EXE;
    i tried to fix this command and write
    "LOAD;SOLITAIRE.skin;Solitaire;D:\Program Files\Tricks\TRICKS.EXE;!FreeWClass!FreeCell"
    but when i push the button freecell the tricks arcade will run correctly but not in SOLITAIRE.skin
    so what have i changed in prev command and parameters to load my arcade games in SOLITAIRE.skin not outside
    and thanx 4 help
    Jan 2007
    East Central FLA
    I suggest you read up on how to "launch" a program - one sure error you have is the last element, i.e., !FreeWClass!FreeCell that's what Windows thinks is the name of the Free Cell window, you need to find out what Windows thinks is the name for your program Tricks.
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    That bit at the end is the window name and it needs to relate to the new exe,the skin file is still set up to embed Freecell but that window isn't the one thats running.
    Use a program called winspector spy to get the window name of Tricks.exe and insert that window name in place of the previous one and it'll work.
    Get winspector here = http://www.google.co.uk/url?q=http:/...H76kxCWQiznm3w
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ride Runner RR's Myspace
    May 2006
    lbridges , griff1 and guino thank you for help
    guino :
    i used Winspector and run my arcade game "Tricks" this an information in Winspector
    classname is : TForm1; and i write this command :
    "LOAD;SOLITAIRE.skin;Solitaire;D:\Program Files\Tricks\TRICKS.EXE;!TForm1"
    but i don't know what i must write instide of Solitaire and should i to double this part of command !TForm1!TForm1
    thanx for help
    agian sorry about my bad english
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can leave that blank or place the name of the screen to be "spoken" when no music is playing.
    Regarding the Classname, seems right (TForm1), but if the window has a title as well, then you can add that to the last parameter on the load command like !TForm1!windowtilte .. which is recommended when possible.
    May 2006
    guino thank you very much for helping
    i almost undurstand but there are one thing i didn't know where i find it
    windowtitle where can i find it in Winspector Spy programe
    thanx agian
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    i see you use the first skin of simplistique.
    is it because your screen is working in 800x480 pix ?
    the call for games are very simpel if you know how it works.
    your line: "LOAD;SOLITAIRE.skin;Solitaire;D:\Program Files\Tricks\TRICKS.EXE;!TForm1"
    Load; = Load a file
    Solitaire.skin; = the Backgroundskin for the Game
    Solitaire; = the Name of the Game you want to play... for you new TRICKS
    D:\Program Files\Tricks\TRICKS.exe; = The folder where your file is and his NAME
    !TForm1 = Windows File Name ... i think... Form1 is enough
    so, your line must written:
    "LOAD;SOLITAIRE.skin;Tricks;D:\Program Files\Tricks\TRICKS.EXE;Form1"
    if your screen works with 800x600 pixel have a look to Simplistique II transparent in this forum.
    May 2006
    gf-ler thank you
    and thanx for all member were helped me
  1. Body Filler For Kick Panels?
    By AltimateX in forum Fabrication
    Last Post: 10-21-2007, 10:31 AM
  2. Would you hide the body for you son?
    By NYCdesignkid in forum Off Topic
    Last Post: 06-26-2005, 04:12 PM
  3. Does any body have theses webcams?
    By Danceheaven in forum General Hardware Discussion
    Last Post: 06-28-2004, 08:09 PM
