Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Advanced Skinning Question
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well I'm not sure this is even possible, and I think I've tried about everything from skin commands.txt to achieve this look without luck. I've never seen it done in a RR skin, but I know RR is powerful and it may be possible so here is what I want to do.
    I am currently coding a Carwings replica skin for RR and I am on the GPS menu and I have it mostly done but I am trying to get a very accurate look so here goes:
    Have the GPS art as normal with an embedded application (iGuidance) inside of it. Then I want to draw the menu "over the top" of the embedded application. Ive tried using the IMG command and it works but iGuidance still takes precedence and shows on top of everything including my menu. I've tried messing with the "SETTOPMOST" and "SHOWWINDOW" commands without luck. So is what I want to do within the limits of RR?
    Since pictures are worth a thousand words here are 2,
    first one is an actual screencap of RR running the carwings skin and the second is a photochop of what I would like it to look like.
    Any help is welcomed and thank you in advance for even any ideas. I know there is some real talent out there!
    Jan 2007
    dundee, il
    Quote Originally Posted by blk02si View Post
    i dont think that roadrunner can do that yet, at least not unless it was added very recently. skin is looking great by the way
    david
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    LS figured out a way to put an IG .exe plugin over the IG area with corresponding icon.
    Might want to try asking him or checking out his skin.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    is possible, i did it in my old elco media skin, is a very old threat, LS has a script called igControl, and flashdeck has it also.
    Jul 2005
    Motorcity
    Blog Entries
    1
    These items are still square though. FlashDeck & IGcontrol. I am attempting to get a curve overlay using art rendered by RR if possible. If I have to use/write another app to make it happen I will, just wanted to know if this type of rendering is possible just using RR.
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    flash. thats the only way its possible. draw your overlapping picture in photoshop and save it as a png. swishmax can do it, if it is possible.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Liquid Smoke has some code to do this. His latest code supports PNG's for use with AUtoIt. Basically AutoIt places the image at a defined X/Y location. With the PNG support, you can simply make the "outter curve" of the image overlay transparent.
    My Fiero Build Thread
    Mar 2006
    Houston, TX
    Quote Originally Posted by JohnWPB View Post
    taht would work too, clever.
    Aug 2004
    Germany
    Can't you just open a MENU with transparent .PNG-files ?
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. Skinning question
    By ayclens in forum FP Skins
    Last Post: 07-28-2005, 12:57 PM
  4. Photoshop skinning question
    By wysocki in forum RR Skins
    Last Post: 07-26-2005, 05:31 AM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
