Results 1 to 5 of 5
Thread: GPS Indicator not working
    Aug 2004
    Germany
    I try to put an GPS indicator on my skin, but I can't get it to work.
    This is what I've put in my skin-file:
    Code:
    /, Y, Back Slider file path
    Y01,"gpsslider\slider_*.gif"
    /,   x   y   w   h   x1  y1  w1  h1  O Style Pointer file path h2  Code  tooltip
    S01,671,007,028,022,661,007,028,022,H,01,"gpsslider\pointer.gif",01,GPSSIGNAL,""
    Within the skin folder I have created the folder gpsslider. It contains an completely transparent pointer.gif and 20 slider files (slider_0.gif to slider_20.gif).
    -slider_0 to slider_2 indicate a bad signal
    -slider_3 and slider_4 indicate medium signal
    -slider_5 to slider_20 indicate a good signal
    The GPS signal in RR is working, I've lock to 5-6 satellites, still my skin shows the symbol for a bad signal.
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Konrad View Post
    Code:
    first question, is the box you want to show 28x22 pixel.
    why you want a pointer, who should be 1 pix high, when you split the signal into 20 screens ?
    S01,671,007,28,22,661,007,28,22,H,01,"",28,"GPSSIG NAL",
    thats enough.
    Aug 2004
    Germany
    Its not really a slider, but just a sattelite symbol in red, yellow and green. The pointer isn't required, but I guess you need to supply one for sliders, don't you ?
    Aug 2005
    germany
    no you need no one.
    dont forget the "Anführungszeichen" in front and behind GPSSIGNAL and all will work.
    Aug 2004
    Germany
    Well, duh ! How could I miss this ^^ ? Ok, I'll try, thank you .
  1. G4 GPS stopped working
    By spiro in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 12-18-2007, 02:23 PM
  2. NMEA GPS not fully working
    By stric in forum FreeDrive
    Last Post: 03-07-2006, 04:25 PM
  3. MapMonkey Gps working but not on map
    By BOND007BE in forum Map Monkey
    Last Post: 03-11-2005, 09:02 AM
  4. Deluo Gps not working
    By juixy in forum GPS
    Last Post: 07-26-2004, 05:16 PM
  5. Got GPS 16 working
    By tekknikal in forum General Hardware Discussion
    Last Post: 06-16-2002, 06:55 PM
