Results 1 to 7 of 7
Thread: would this system with 256 and 512 ram make any difference?
    Dec 2007
    This is what i have and i am thinking about gettting rid of it and upgrade to 512.. Knowing the chip and cpu and all, would it make any difference in terms of performance using any of the fully functional skins for RR?
    I like to use ilist and vis and all.. If it makes significant difference then i'll upgrade it to 512.
    AMD Geode LX800 CPU running at 500 MHz with 256 ram..
    http://ultramobilepc-tips.blogspot.c...ga-review.html
    it might cost me between 30 to 50 bucks to upgrade.. But i was told vega with 512 gets really hotter than 256..
    What do you guys think, worth the money?
    Thanks..
    Elsewhere
    Moved to General Hardware
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by brandensin View Post
    Thanks..
    You can get a gig for 30 bucks, so go for that. 512 I would say is better than 256 because XP will eat some too, and all that eyecandy needs more.
    1.9in x 2.9in -- 47mm x 73mm
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    Definitely go for more RAM...personally I don't like to run XP with anything less than 1GB
    Elsewhere
    Quote Originally Posted by DarquePervert View Post
    Moved back to RR skins.
    I misread the post.
    Sorry for the confusion, brandensin.
    And I agree. For performance considerations, more RAM is always better.
    How about the Wiki?
    Dec 2007
    Thank you guys. I knew more ram is better, just wasn't sure if more ram would do anything good with a really weak processor i have in my toy.. ^^
    man, i should have purchased 512 from the first place.....
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    just 1 thing to remember:
    if u're using the hybernate function, you'll need the same memory size plus some bytes of free space to hyernate
    soh, the more ram u got, more space required
    []s
  1. Ram: 256 ou 512 MB ?
    By MoDu in forum Operating System Optimization
    Last Post: 11-26-2007, 09:06 PM
  2. 256 MB of RAM minimum requirements
    By urosbe in forum Centrafuse
    Last Post: 06-15-2007, 06:07 PM
  3. WTB: 256 or 512 pc133 SD ram
    By Sonicxtacy02 in forum Classified Archive
    Last Post: 07-30-2005, 10:34 AM
  4. WTB: Low Profile RAM 256 or 512
    By Uconnputer in forum Classified Archive
    Last Post: 12-17-2004, 03:54 PM
