Page 16 of 31 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 302
Thread: Carwings v1.0 - RELEASED
  1. #151
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Machinehead View Post
    Well yea, I tweaked all the skin commands to the Sirius ones. i.e. SRReload, SRFav, etc, etc, etc. That part is east and always works fine. But the sat and ter bars don't work. There must be more to it than just switching all the XMs to SRs. I'll have to do some more research.
    Just a though, is there a specific path that I need to put your indicator images into?
    I think just switching XM to SR should work.
    From "skin Commands.txt" "SRSAT" - SIRIUS Satellite Signal Quality
    "SRTER" - SIRIUS Terrestrial Signal Quality
    Is the folder called slider_battery in your carwings directory? If it is not, copy it from the DFX folder to the carwings folder and that should fix it. That is the path I used for the XM signal. Do you have the recolored slider images? If you don't I will post them tonight when I get home.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  2. #152
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by fixerofallthing View Post
    I have to look, but I think I'm a dummy and forgot to copy that folder into my carwings directory.
    That's what I get for working on this at 5 in the morning.
  3. #153
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    Quote Originally Posted by Enforcer View Post
    Can you tell what it is yet?
    Looks like screen lock control
  4. #154
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by venealis View Post
    Sort of, it's Access Control (the title in the picture kinda gives it away )
    Anyway here is the main screen of Traffi Cams. It woul look nicer if we could get the floating menu over it but trouble is when it switches screens you would need to change the icons and functions in the floating menu, and traffic cams would need to be able to accept commands from RoadRunner. Hmmmmmm
  5. #155
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Kind-a begs for those numbers to be bigger. IMO
  6. #156
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Looks really good Enforcer! I am very interested in the Upd8 menu.
    Just so you know the floating menu is all AUtoIT. The script sends commands directly to iGuidance, it does not use RR to send the commands at all. AUtoIT is quite clever in how it can pass commands to other windows applications, so the only thing RR needs to handle is the embedding. As long as the traffic CAM app has a window title and some way of passing key strokes, mouse clicks, shortcuts, etc. to it the floating menu would work as is does in the CWiG script.
    I want to add a left menu to the mixer screen, and also am going to experiment with having a float menu over the video screen.
    Quote Originally Posted by treetop777 View Post
    The buttons for the #'s are much larger than the # itself.
  7. #157
    Jun 2007
    Alright, I finally finished modifying Fixer's XM screens to Sirius. The screens are attached.
    I'm going to take a run at Coverflow next.
    Edit: I noticed that the date position didn't match the other screens. I fixed it.
    Attached Files Attached Files
  8. #158
    May 2005
    Lawrenceville GA
    That looks nice! I see you got the sat signal issue sorted out. Great Job!!
  9. #159
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by blk02si View Post
    I have taken the NUMOSK graphic and and used that to keep it standard with the rest of the skin, as blk02si says the buttons extend to the lines and meet halfway between each other.
    Well for it to work with traffic cams it would also need to be able to receive commands to tell it to change graphic when TC switches screen.
    Here's the two screens
    The first is the main camera screen (of which there are three, but the buttons on the left stay the same) then second is the search screen which has different buttons and therefore button codes, these are screens within my program not RoadRunner screens, so the floating menu would have to notified that which screen my program is in and then charge appropriately.
  10. #160
    Jun 2007
    It's amazing what happens when you actually copy everything over.
    All the credit goes to you, I just worked with your code.
  1. MobileWeb v1.0 for MediaCar Released
    By stevieg in forum MediaCar
    Last Post: 03-31-2010, 05:21 PM
  2. [WIP] cwings - Nissan Carwings skin for CF
    By marazi in forum CF Skins
    Last Post: 02-19-2009, 06:25 PM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 03:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 11:22 AM
  5. FrodoSkinner v1.0 Released
    By Jawbreak in forum FrodoPlayer
    Last Post: 12-30-2004, 01:34 PM
