Page 22 of 31 FirstFirst ... 1213141516171819202122232425262728293031 LastLast
Results 211 to 220 of 302
Thread: Carwings v1.0 - RELEASED
  1. #211
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I don't have radio in my setup, that's why there isn't a radio button in that menu. You can make that menu yourself with the SDK. But if I remember tonight, I'll whip up a menu for you.
  2. #212
    Feb 2008
    thanks i tried to start the sdk but it dont like my vista pc so i cant change it
  3. #213
    Jun 2007
    All set Xargon. That should do it for you.
    Attached Files Attached Files
  4. #214
    Feb 2008
    You Are the Man!!!
  5. #215
    Feb 2008
    heres a quick question how do i get the hd radio to work under roadrunner?? i dont hear the relay click when i go to the hd radio tab
  6. #216
    Jun 2007
    You probably need to configure it, blk02si has it, I'm sure he can point you in the right direction, the other option is to search the main RR forum for information.
  7. #217
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Xargon321 View Post
    Set the comm port is the first thing come to mind.
  8. #218
    Feb 2008
    well treetop that would be nice but there is no port setting in the config prog. i found i might have to add a command to the rr.ini Hdradioport=2 or what ever poet i need ill try this and see if it works
  9. #219
    Feb 2008
    well got that taken care of it works on the the next thing. with is there a way to get audio stream switching within the skin? i have alot of anime that is dual audio and would like to beable to get the media player classics menus or have a decicated button to switch streams also a way to disable subtitles. also it possible to have a playlist style setup where you start one video file and it automaticly plays the next one?
  10. #220
    Feb 2008
    Well after messing around with the skin editor i got it to work do now i can add stuff if i figure it out.
    with mpc i know the key binding to switch audio and subtitles but i dont know how to format them to use in the skin editor
    i know its "sendkey" but after that i dont know
    shift a
    shift s
    how do i format them to work when i press them in the skin?
  1. MobileWeb v1.0 for MediaCar Released
    By stevieg in forum MediaCar
    Last Post: 03-31-2010, 05:21 PM
  2. [WIP] cwings - Nissan Carwings skin for CF
    By marazi in forum CF Skins
    Last Post: 02-19-2009, 06:25 PM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 03:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 11:22 AM
  5. FrodoSkinner v1.0 Released
    By Jawbreak in forum FrodoPlayer
    Last Post: 12-30-2004, 01:34 PM
