Page 23 of 31 FirstFirst ... 13141516171819202122232425262728293031 LastLast
Results 221 to 230 of 302
Thread: Carwings v1.0 - RELEASED
  1. #221
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Xargon321 View Post
    Well after messing around with the skin editor i got it to work do now i can add stuff if i figure it out.
    with mpc i know the key binding to switch audio and subtitles but i dont know how to format them to use in the skin editor
    i know its "sendkey" but after that i dont know
    shift a
    shift s
    how do i format them to work when i press them in the skin?
    Shouldn't be that complicated, have you been here HD Radio Cables READY! every possible broblem with the HD radio have been discussed there. (then again, i'm assuming you have a Vestion HD Radio).
  2. #222
    Feb 2008
    i got the hd Radio working fine now im asking how to code shift s and Shift s as buttons in the video player skin
  3. #223
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    "SENDKEY;+a"
    "SENDKEY;+s"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #224
    Feb 2008
    i mean somthing like "sendkey;Shift+a" is that the correct formatting?
  5. #225
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Whenever RR starts i get a windows error that Iguidance3.0 must restart.. only with this skin..why?
    10 acura TL tech
    10 BMW S1000RR
  6. #226
    Sep 2006
    Quote Originally Posted by john05srt4 View Post
    i removed it in startup.
  7. #227
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Remove:
    "ONSKINSTART","RUNQ;$GPSPATH$"
    From the ExecTbl.ini file in the skin folder.
    That line preloads the gps app so it is smooth when going to the nav screen.
    Well so far Enforcer has not responded to my PM so the screens he worked on my not be in the update.
  8. #228
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by blk02si View Post
    Yeah, sorry about that.
    I need to get onto the computer I did those on and then put them in a zip in a way they are supposed to go.
  9. #229
    Jun 2007
    St. Louis
    anyone else experience something like the following?
    carpc boots up, everything seems to load fine. Music will play as normal, however when going to the Navigation screen, only iGuidance comes up - no menu on the left side.
    Seems to happen intermittently, did it all day yesterday. Didn't have time to mess with it so I just left it. This morning I got into the car to head back to the hospital (son is in, looooong story) this morning and it worked normally. Left the hospital about 1.5 hours later and the menu to the left of the iGuidance screen was gone again.
    I'm going to try to wipe out the RR install and re-install it and the skin as I think something strange is going on at a deeper level since the RRConfig.exe won't even load.
    also - any way to double-tap the visualization to make it full screen as before instead of just opening the configuration? Or is that because I'm using Winamp 2.95 instead of 5.13?
    Thanks! and btw...everyone that sees the skin absolutely loves it!
  10. #230
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    That happened to me once, but I have no idea why it happened and it hasn't happened since.
    If you keep the default IG skin it doesn't really matter other than it's annoying.
  1. MobileWeb v1.0 for MediaCar Released
    By stevieg in forum MediaCar
    Last Post: 03-31-2010, 05:21 PM
  2. [WIP] cwings - Nissan Carwings skin for CF
    By marazi in forum CF Skins
    Last Post: 02-19-2009, 06:25 PM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 03:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 11:22 AM
  5. FrodoSkinner v1.0 Released
    By Jawbreak in forum FrodoPlayer
    Last Post: 12-30-2004, 01:34 PM
