Page 6 of 31 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 302
Thread: Carwings v1.0 - RELEASED
  1. #51
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    @EL Camino
    Started digging into your scripts a bit more and just wanted to let you know I like the way you laid it all out, very easy to customize!
    Here is a screencap of my custom menu and the only issue im having, which is the 'wait' menu is off a bit. I wanted to take a look at the AUtoIT code but I cannot decompile the exe. I'm using Exe2Aut and it says only 3.2.5.1 scripts or earlier are supported. So you must be using a newer version. Perhaps you can post the au3 file so I can see if I can get the wait menu to line up.
  2. #52
    Feb 2007
    Very , Very nice work just need it with green text to match ford and that would super nice (hint, hint)
  3. #53
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by fixerofallthing View Post
    For now I ditched the preset buttons until I can work on the art a bit.
    This is what I am using for now. Please feel free to make suggestions.
    The only thing I would change is to find a way to squeeze in the channel art for the current channel.
    Maybe replace the EQ button with that.
    I also agree with blk02si, that you should change the signal meters to orange.
  4. #54
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by millsy View Post
    Green is the next color I am going to work on, my interior is also Green
  5. #55
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Blk - That "please wait" is off center on my test machine but it centers perfect in the truck - leave it alone and try it in your car.
  6. #56
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    ok, for a limited time offer heres the source, and with the pressed effect.
  7. #57
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thanks EL Camino, I like the addition of the "ONSKINSTART","RUNQ;$GPSPATH$" in ExecTBL, makes the transition smoother.
    Your code looks tidy and organized, thanks for sharing, its helping me understand AUtoIT much better!
    I am still not getting the highlight on button press though, I think im missing the press art, when you first started working on CWiG you sent me a sample that had one of the buttons working on the menu. Here is the file that you sent 'btn1.png', I assume you have 7 files, one for each button?
  8. #58
    EL CAMINO's Avatar
    Jul 2005
    not using that, i use the labels now, is faster and use less cpu, AND the way you have the skin, the labels change color on button press, so i use that, even my via m10k has no problems this way.
  9. #59
    Sep 2007
    I've started work on movie times plugin screens here is my first SS. Any comments I think the menu on the left make take up to much room not sure.
    BTW the space under zip is going to show the current zip code you are searching.
  10. #60
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by EL CAMINO View Post
    I am also running the m10k I compiled the au3 files from your source and it works perfect! Even the 'wait' pic is now right. Thx again EL.
    Movie menu is looking good Andrew.
    Here is a IG_hider that matches the skin a bit better, right click, save as
  1. MobileWeb v1.0 for MediaCar Released
    By stevieg in forum MediaCar
    Last Post: 03-31-2010, 05:21 PM
  2. [WIP] cwings - Nissan Carwings skin for CF
    By marazi in forum CF Skins
    Last Post: 02-19-2009, 06:25 PM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 03:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 11:22 AM
  5. FrodoSkinner v1.0 Released
    By Jawbreak in forum FrodoPlayer
    Last Post: 12-30-2004, 01:34 PM
