Results 1 to 5 of 5
Thread: Problem /w SD Dir List properties (PATH)
    Feb 2008
    Hi to all who can help me.
    In RR.INI my picspath=C:\PICS\
    Here some extracts:
    menu.skin -->
    B03,640,100,150,70,"PICS","" ..........which loads
    picviewer.skin -->
    SD,00,01,00,00,"c:\plan\","*.*",true
    S01,510,100,190,380,255,000,000,000,000,000,255,00 0,000,255,255,255,000,000,000,255,255,255,TRUE,14, "Arial:B"
    J01,010,100,480,380,"PICTURE:A"
    What does not work is browsing in "c:\plan\" or
    What works is the true/false term in the above SD-command
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    picviewer.skin is ruled by rr.ini variable "picspath"
    Either set the "picspath" variable to your picture directory or add a "SETPATH" command after you load picviewer.skin
    i.e.
    PICS||SETPATH;<your dir path>
    If you want to filter only one file type (i.e. *.jpg only), just create another custom picviewing skin w/ the properties you already provided.
    From Skin Commands.txt
    /, (SD) Directory List Properties -- (May be Extended later)
    /, a Disp w h Path Files ShowExt
    SD,AA,MODE,ICOW,ICOH[[[,PATH],FILETYPES],EXTENSION]
    The above defines extra propperties for the folder List on the current skin.
    AA is the Alignment of the Directory List (00=Left, 01=Right, 02=Center).
    Disp Mode sets the mode of display (00=Normal List, 01=Thumb Preview Icon List, 02=Thumb Preview Icons).
    Note: iLists require that you set Disp Mode to 03
    ICOW defines the Width of the Icon to display on display modes 1 and 2.
    ICOH defines the Height of the Icon to display on display modes 1 and 2.
    PATH defines the Directory/Folder location to display initially (OPTIONAL). If not present the path
    from the previous screen is used. Use "DEFAULT" for default path when needed. USE QUOTES.
    FILETYPES defines which filetypes to display. i.e. ".jpg,.bmp,.gif" -- "*.*" can be used for all files.
    EXTENSION defines if file extensions should be displayed. TRUE for displaying extension, FALSE otherwise.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    picviewer.skin overrides the path and files you specify in the SD definition -- exactly so they work from settings defined in RR.INI and so it displays "known" file types. If you do a similar thing in a different skin it will work, but you'll need to an Indicator code to display the image as the J definition won't work by default.
    Ride Runner RR's Myspace
    Aug 2006
    Sun Diego
    Quote Originally Posted by guino View Post
    In addition, if you want to filter only image files in your custom picviewer dl list, use the following format for the filetypes:
    "*.jpg;*.png;*.gif;*.bmp"
    GL
    Feb 2008
    Thank you all
    folks
  1. HQCT Module (new thread following HU RDS/RDBS)
    By racemier in forum Hardware Development
    Last Post: 12-15-2011, 03:14 PM
  2. Weird Registration Code and Hardware Code problem
    By lookinco in forum StreetDeck
    Last Post: 09-30-2006, 03:25 AM
  3. Odd problem with the browser list.
    By slackervn in forum Road Runner
    Last Post: 09-10-2006, 01:38 PM
  4. Xm Scroll List Problem?
    By zenpoppa in forum Road Runner
    Last Post: 06-06-2006, 11:41 AM
  5. Replies: 4
    Last Post: 05-01-2006, 12:48 PM
