Results 1 to 10 of 14
Thread: skinning question
    Newbie gmcmillan's Avatar
    Feb 2008
    Canada
    skinning question
    i'm working on a skin for road runner and for some reason whenever i load the road runner it only loads the top corner of the skin. any ideas why?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    got any screenshots
    make sure you have the image files for the .skin you are accessing, menu is the first one so make sure you have the image files for that.
    Also make sure you have the correct background path set if you are using transparency.
    make sure you have registered the GDIplus dll or have run the new RRconfig.
    Feb 2008
    Canada
    there's a screen shot. you can see it loaded in the top left corner. sometimes it works and sometimes it doesn't. so i'm not sure what's up.
    [media]http://www.digital-basement.org/images/Rx8-skin/error.jpg[/media]
    i will check the other things when i get home later.
    Feb 2008
    Canada
    ok i've got a registered GDIplus.dll and the new version of RRconfig. i still have the same problem. any ideas?
    also the skin seems to load in the RRconfig previewer fine. but not when running RR
    i can load other skins just fine, it's mine that won't load properly i've used the skin editor and done it manually and still same thing and my images are fine. i dunno what's up
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Does it do this at the very start?
    If so email me the general.ini, menu.skin and images used in the menu.skin and the same for that screen above and I'll try it on my system.
    Email is on my website as contact webmaster. Website link in sig.
    Feb 2008
    Canada
    yes it does it at the very start
    email sent
    Feb 2008
    Canada
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    on my pc it runs.
    BUT, your .skin files are not complete. look in other skins how a skin is opend.
    MEDIACAR Skin
    MEDIACAR menu. Skin
    menu_OFF.jpg,menu_OFF.jpg,menu_on.jpg,menu_DOWN.jp g
    you only write
    MEDIACAR Skin
    MEDIACAR menu. Skin
    if your other screens are not available, write:
    MEDIACAR Skin
    MEDIACAR menu. Skin
    menu_OFF.jpg,menu_OFF.jpg,menu_OFF.jpg,menu_OFF.jp g,
    the same is in the audioplayer skin.
    also: the field for directorylist is wrong and the buttons PGup..Up..down..PGup must be outside the playlist field.
    Feb 2008
    Canada
    see it works on a fresh install of road runner until i use rrconfig.exe than when it opens it only shows the top left corner of my skin.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. Skinning question
    By ayclens in forum FP Skins
    Last Post: 07-28-2005, 12:57 PM
  4. Photoshop skinning question
    By wysocki in forum RR Skins
    Last Post: 07-26-2005, 05:31 AM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
