Results 1 to 3 of 3
Thread: embedding an exe app. in flash?
    Apr 2007
    The exe link is corrent, but dont run. I solved this problem, but exe donīt embedded. There are a code or way for embedding a program into skin window using flash? Thanks.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't know if flash would have all the low level functions needed to embed an application -- I don't believe it can.
    Post the command you tried to use for embedding the app directly and we'll try to help you.
    Ride Runner RR's Myspace
    Apr 2007
    I try different codes, but any of these embedded the application completely. Else, if I will set a button (i.e. "E" key) the skin donīt run, because on top is or skin, or application. I post the codes and explain (all in order "on release"):
    getURL("fscommand:load;;!Syg ic DRIVE;C:\RR\DRIVE\DRIVE.exe |-no-safety -r800x550;!Sygic DRIVE||ACTIVATE;Sygic DRIVE",""); ---> this code donīt embedded the application, and donīt started with RR ( Needed execute first to embedd in the window)
    fscommand ("LOAD;");
    fscommand ("RUN;C:\\RR\\DRIVE\\drive.exe;drive");
    ---> with this code, I start the app, but the problem is when I try control with buttons os flash skin. Size is encoded in (c01,xxx,xxx,xxx,xxx).Thanks for all Guino. I think this code is wrong for flash skinning.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Flash Skin Tutorial?
    By Cruizer in forum RR Skins
    Last Post: 01-10-2008, 12:02 PM
  3. Can not delete music from flash drive
    By knyarko in forum StreetDeck Bug Reports
    Last Post: 06-27-2007, 04:23 PM
  4. Suspend to Flash??? S3.1?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 05-10-2006, 04:39 AM
  5. Replies: 24
    Last Post: 03-03-2006, 01:36 PM
