Results 11 to 20 of 21
Thread: suggestion and thanks
  1. #11
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Posting your code it would be a be easier to help you, rather than posting the debug log.
  2. #12
    Dec 2007
    Here you go,
    B17,399,535,72,61,"RUNw;wscript.exe|"$SKINPATH$Scr ipts\night.vbs"||RELOADSKIN",""
    B17,324,535,73,61,"RUNw;wscript.exe|"$SKINPATH$Scr ipts\day.vbs"||RELOADSKIN"",""
  3. #13
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    i'd really like to help, but this is way over my head. Your already speaking what i can't understand. hope you can resolve and share. HINT HINT
  4. #14
    Jul 2005
    Motorcity
    Blog Entries
    1
    are you writing the script in visual basic 6?
  5. #15
    Dec 2007
    shoot... extra double quote on the second command... problem resolved.. works great...
    venealis, put the zip content in the skin folder,
    open the vbs files with notepad, then replace "bmw e36 green" with whatever skin u want
    then, in menu skin, have a button with an icon(maybe sun and moon) for day and night, left half of that button calls the first command above, right half calls the second command.. Then u set, it will change the font color instantly in runtime... this means we will be able to change anything we want inside that font_color.txt file... even font type,size too...
    Cheers!!!
    ---edit
    i'll try to convert the vbs to exe..
    Attached Files Attached Files
  6. #16
    Dec 2007
    ok..i changed to single file.. u need to pass the skin name and mode instead of changing the vbs file..
    B17,399,535,72,61,"RUNw;wscript.exe|"$SKINPATH$Scr ipts\font_change.vbs" "bmw e36 green" "night"||RELOADSKIN",""
    B17,324,535,73,61,"RUNw;wscript.exe|"$SKINPATH$Scr ipts\font_change.vbs" "bmw e36 green" "day"||RELOADSKIN",""
    found out there's no such thing as true vbs to exe.. whatever is out here is just another extrator...
  7. #17
    Apr 2006
    Richmond, VA
    thanks alot will give it a try as soon as possible
  8. #18
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    ..and this is supposed to do what? <man searches for "confused" smiley but can't find it so uses smiley that don't make sense>
  9. #19
    Dec 2007
    Quote Originally Posted by treetop777 View Post
    Well, we just wanna toggle the font color for night and daytime with a single click in hoping using it with gamma would give us better visibilty.
    That's what this will do... Nothing fancy as usual..
    So, treetop, what color do you use during day and night time?
  10. #20
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by brandensin View Post
    I see, thanks.
    Haven't given much thought to day/night colors, lime green is pretty good for day tho'
