Results 1 to 6 of 6
Thread: is having two custom lists on one skin possible?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I dont THINK this is because i believe RR has a limit of 1 playlist/directory list/custom list per .skin. But just to be sure is it possible to have 2 custom lists? I've got a file manager functional using an autoitscript and rr code and i wish to have both source and destination lists on one screen. If push comes to shove i'll just use one custom list and split the vars via flash but two custom lists would certainly be a better option. And dont mind the skin.. i was just playing around.
    Live mp3Car Facebook Chat
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    I couldn't around it.
    I had to split my "filemanager" into two skins.
    *sub'ed*
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Sal R. View Post
    *sub'ed*
    if push comes to shove i'll have my script read both source and destination to one list then split the list at a delimiter with flash. i dont wanna HAVE to do that tho !
    Woodbridge, VA
    Blog Entries
    55
    well seeing as noone has replied in a day and im' really impatient i went ahead and just used one custom list split in flash.. results look great!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    One per screen, normally having two lists in the same screen gets too clogged up or uses up too much space so you can't fit all that's necessary in the same screen, so you can only mix up one playlist, dirlist, custom list in the same screen but not two of the same.
    Ride Runner RR's Myspace
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by guino View Post
    thanks for the clarification G. Its workin just fine now as it is.
  1. Working on a new skin, easy to read, easy to use
    By monkeyracer in forum RR Skins
    Last Post: 01-12-2008, 05:34 PM
  2. cAVeLive English repack + new custom skin
    By Themutt in forum Other Cool Front Ends
    Last Post: 09-12-2007, 12:54 AM
  3. Custom Software Skin
    By strandtc in forum Software & Software Development
    Last Post: 03-09-2006, 09:23 PM
  4. Replies: 8
    Last Post: 11-30-2004, 02:07 AM
