Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 我的RR不能用含有png格式图片的
    Aug 2007
    我的RR不能用含有png格式图片的
    我的Road Runner不能用包含有“.png”格式圖片的皮膚(skin),只要用含有“.png”格式的皮膚(s kin)就變成如附件所示的顯示,並導致不能使用。請問是什麼問題?
    請精通中文的朋友給翻譯一下。
    以下是啟動Road Runner後出錯的螢屏抓取:
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    in a DOS box, goto your Roadrunner folder and type in the following ...
    C:\windows\system32\regsvr32 GDIPlusWrapper.dll
    Then re run roadrunner.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    Mar 2008
    Воя смотрю япошка мы с тобой оба как шланги сидим с незнанием английского языка
    RUSSIA - WINER!!!
    Nov 2007
    Ok, i can't understand anything that the OP said. But, as they say, a picture says a thousand words.
    My RR is doing it at the moment too.
    How do i do a DOS box to input
    Mar 2006
    Colorado, but Canadian!
    Start-->Run-->cmd
    Or if you dont have the Run box Start-->Programs-->Accessories-->Run-->cmd
    that will bring up the DOS emulator.
    Also you dont really need that full path if your globals are set correct. So if you just type regsvr32 it should know what you mean
    1.9in x 2.9in -- 47mm x 73mm
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I am out of here.
    This is getting way over my head.
    I think I will relax a little.
    ad watch it from the distance.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by 2k1Toaster View Post
    开始-> "运行- >" C M D公司
    或者如果你不用有运行框开始-> "程序" - >配件-> "运行- >" CM D公司
    这将造就的DOS模拟器。
    此外,你不用真的需要这种全路径,如果你的全局变量是一套正确的。因此,如果你只需要输入regsvr32 应该知道你的意思
    if the OP can't write english, I suspect he also can't read it.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Valheru View Post
    在一个多盒,直接到你的RoadRunner文件夹,并键入下列… …
    在C : \ Windows \ \ regsvr32 gdipluswrapper.dll
    然后重新运行的RoadRunner 。
    JIC
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Yea you bablefish
  1. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. Road Runner Setup skin...
    By bati in forum Road Runner
    Last Post: 09-07-2006, 02:44 AM
  4. Replies: 2
    Last Post: 08-28-2006, 11:55 PM
  5. Replies: 78
    Last Post: 09-08-2005, 07:29 PM
