Results 1 to 6 of 6
Thread: ALBUMART of the specified item
    Newbie banderas's Avatar
    Mar 2007
    Moscow
    Hi all
    I'm trying to make my own flash skin but I have a problem with making the list...
    The problem is I can't get the ALBUMART of the specified item! ALBUMART shows only the image of the playing item but not the specified...
    I can get the path to it with TRACKPATHXXX but I don't think it's possible to get the name of the image with Action Scripts...
    The basic idea - when you scroll the list, album cover changes at the same time(like with non-flash skins)
    Can anyone help with it?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    playlist or directory list, chances are i've done this in my sonique evolution skin. what are you using flash or swishmax?
    Live mp3Car Facebook Chat
    Mar 2007
    Moscow
    Quote Originally Posted by Sonicxtacy02 View Post
    I mean playlist in audio skin
    I use Macromedia Flash. I've tryied to use JSFL to access to the file system but I don't know how to send global variable to the jsfl and back to the flash and how to run run jsfl from the flash.
    simple example - tracing 'some text' by using JS - MMExecute("fl.trace('some text')") doesn't work
    Yes, I see - you've done it in your sonique evolution skin, but how did you do that? I mean what the logic of getting album path for each track?
    Mar 2007
    Moscow
    Ok, I got it - it's not possible to get the access to the file system by using flash... it needs to develop external script - it's too bad for me
    Woodbridge, VA
    Blog Entries
    55
    i'm not using an external script, but i'm not using flash either i'm using swishmax because its lightyears easier than flash when creating skins. The data i used to determine the art path is the LISTPOSTRACKPATHXXX label i created. the currenly playing track is list position 1 and every list entry after that gets a number, so if you wanted to get the album art for list position 2 it would be available in LISTPOSTRACKPATH2 etc etc. The only issue with doing this is its not very speed friendly (at least in my implementations). I'm considering removing it from my skin in fact.
    Mar 2007
    Moscow
    hmm... ok, I can get path to specific position like "c:\music\artist1\album1\"(this folder contains jpg cover) but how can I get the name of the image to display?
  1. 2003 Nissan Xterra
    By tigergibb in forum Worklogs
    Last Post: 07-04-2008, 08:34 PM
  2. Wrong albumart displaying
    By oddvarr in forum StreetDeck
    Last Post: 03-10-2008, 10:52 AM
  3. Flash ALBUMART Loader
    By LeeVD in forum RR Skins
    Last Post: 01-10-2008, 04:14 PM
  4. Notice :- Flash speed with albumart
    By CdRsKuLL in forum RR Skins
    Last Post: 03-15-2007, 07:39 AM
  5. Albumart bug.. cant trace
    By CdRsKuLL in forum RR Bug Tracker
    Last Post: 02-20-2006, 02:06 AM
