Results 1 to 5 of 5
Thread: New 2 Skinning and starting from scratch.
    Mar 2008
    I am new to this forum and new to skinning as well. I have read through the different tutorials and seem to have a basic understanding of what is needed. I have also tried searching through the forums but none of my keywords seem to do me any good. So my first problem/question i need to tackle is how to setup up the basic foundation.
    What i have done (please correct me if it is wrong) so far. Picked out an image i wish to use as the background for my main screen. I have resized it to the correct resolution. I then made 3 copies. On, Off and down. In RRskineditor3.019 i clicked on create skin. It asked me for a save location and wanted me to pick a file. So i selected the basic jpeg background. it then prompted me for 4 additional jpeg locations (Empty, off, on and down). I selected the 3 duplicate pics of the main one that are named off on and down (i used off in the empty spot).
    So my first question is, do i have all of the pictures laid out correctly and assigned correctly or should i be selecting something totally different for any of those choices. Thanks in advance for any help and i am sure i will progress to more questions as i move along.
    also, if there is a better tutorial that really walks a dumby through starting a skin from scratch point me in the direction and i will gladly go and read first.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    If you design your skin for a touch screen then you need only 2 images as there is no mouseover event. You need only the OFF and DOWN screen, even with the OFF and DOWN screen you have a mouseover effect as the button is highlighted with the mouse over it. This layout would be
    RoadRunner Skin
    RRScreen F-CNS "MENU"
    Menu_off.png,Menu_off.png,Menu_down.png,Menu_down. png
    Now you would have the mouseover event and the touch event on the screen.
    Most all new skins are made now for transparency, so the user can select his/her owen background, therefore the images must be PNG format.
    Low Bitrate frangolfgt's Avatar
    Jul 2006
    Lancs, UK
    'on' is used to show indicators such as random or shuffle being active.
    Skins:
    /showthread.php?t=83814 (R.I.P.)
    /104373-golf-skin.html (R.I.P.)
    /106214-metal-spin-release.html(RIP)
    using own vw gypsy clone
    On 2nd PC: 1st one died.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i would suggest ripping
    BMV2 apart, copy the folder and rename it "YOURSKIN"
    then just change the images . open the skin folder in skineditor and play with the buttons.
    this way you are playing with a working skin.
    if you want transparency.like MDG suggested you will have to change the skin call line in the skin files 3rd line down, most use on/off png's for this.
    after you havemastered that then you can move on to more advance stuff
    makes a good starting point.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by frangolfgt View Post
    I don't use ON at all. I have 2 OFF's and 2 DOWN's and the indicators show up also. It doe'nt even matter what you call them.
    The first image is the empty, You can call it MENU_*&$^% and so on. The 3rd image is the ON, you can call it MENU_847464 and it will still show the indicator.
    You can even use a label as an indicator.
    Lxxx"BYIND;MUTE;=MUTE OFF<<=MUTE ON"
