Ok. i'll change TEK3 only. You're right 'cause MAV1C is working flawless.
Printable View
treetop ... any chance you can get TEK working flawless as well ???? P L E A S E ??? ... lol
I think it's just a matter of making the changes Mracer pointed-out; i'll test it later and see..
EDIT: Made the changes MRacer said and it works; drop these files in the skin folder and that's it; you can delete fullgps.skin.
I also think IG users are going to miss the other shortcut buttons; some have reshacked away the menu buttons from IG so this skin would useless.
Also, I believe you intended for one of the overlay buttons to just hide the overlay but for some reason they both do the same which is to close IG and return to the menu.
Other than that, she's working flawless.
thanks treetop ... for the updated file.
the overlay buttons should work as follows ..
- the left hand (X) will close GPS program and return to TEK3 Main Menu,
- the right hand (Min) button will minimise GPS prog, and show the audio player. if you then select the "NAVI" button from the main menu it will maximise the GPS prog again, but it should still have been running in the background.
I've just completed a small mod for GPS that will display a "GPS" icon in the top display window whenever your GPS program is running, and by pressing this icon you can jump automatically from any RR screen back to your GPS prog. I'll update the RAR file later on today.
As for the IG users ... I'll look at the IG commands that I used in TEk2 and see if I can come up with a suitable overlay for IG users ...
thanks again ... Val.
nicccccccce!!!!!!!:D You guys ROCK! big time!
For a few cheater commands, look at the overlay I have made for mAv1c. There's back, gps menu, toggle 3d mode, toggle north heading, zoom in and out, and mute directions. I've also added audio controls so that I don't have to go back to the other screens just to pause or go to the next song.
my overlay:
http://img.photobucket.com/albums/v2...v1c/RRSS24.jpg
(with reshacked menus...)
thanks monkeyracker ... i'll "look" at your overlay later on this evening, and see what I can throw together for TEK3 ... thanks ...
Updated RAR files on post #1 to include fix for Full Screen GPS.
Added - Dynamic GPS indicator and select button
- Hold-to-lock button on the screen name at bottom of screen.
Also - re-drew the weather screen ...
Right, but since it's not obvious where it is once it's reshacked, it makes it nice to have a specific place for the buttons.
