Results 1 to 8 of 8
Thread: Anyone know how to set an indicator state...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    ...if there are no more folders to browse?
    Basically, as you browse a folder in a DL, an indicator stays "ON" if the current DLPATH has a folder in it and shows a state "OFF" if there are no more folders in it.
    I can do it using AI, but I'd much rather not have to do it that way...
    Anyway to do this solely in RR?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    doesnt the BOTTOMDL indicator do this? only opposite.. its off when theres more stuff and on when your at the bottom of the directory list. (least i think so.. never used it personally)
    Live mp3Car Facebook Chat
    Aug 2006
    Sun Diego
    BOTTOMDL just indicates if you can pgdown past the current screen regardless of the DL content.
    All the arrows in the skin above are indicators. What I want to do is to turn "off" the right arrow indicator if there are no more folders to browse in the DL window. I've been wrapping my head around this for a few days now with no RR-based solution in sight.
    Woodbridge, VA
    Blog Entries
    55
    yea i dont see a way of doin that in RR either. I dont believe rr stores a folder count to measure its folder position.
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    you could use flash to set up an "if" statement: (obviously not flash code)
    -SETVARBYCODE;DLTEXT1;DLTEXT
    -button w/ command BROWSE
    -IF statement:
    if DLTEXT == DLTEXT1
    fscommand(set indicator off)
    ETC.... basically it will turn the indicator off if you hit browse and the current selected item doesnt change. thats the only way i could think of it recognizing whether the folder has changed or not. as for turning it ON, not sure yet.
    Aug 2006
    Sun Diego
    Quote Originally Posted by tundra2000 View Post
    -IF statement:
    I used something similar using RR's EVAL function in one of my earlier attempts, but it's not as clean working as I would like...
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    what skin is that Sal?
    Aug 2006
    Sun Diego
    Quote Originally Posted by blk02si View Post
    Just a new skin I'm working on. I've gotten bored w/ MMI and wanted to have something more visually appealing in my carPC.
    The Skin Browser:
    It really is amazing how flexible RR is.
  1. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  2. car sterio set up what you think
    By franco90 in forum Car Audio
    Last Post: 10-29-2005, 06:37 PM
  3. Recommend a set of 6.5" components...
    By hd54321 in forum Car Audio
    Last Post: 10-22-2005, 01:55 PM
  4. 2 sub set up
    By GeeZeR in forum Car Audio
    Last Post: 07-30-2005, 01:26 AM
  5. How to set Freedrive directions volume
    By Phythorian in forum Road Runner
    Last Post: 07-28-2005, 06:35 AM
