Results 1 to 10 of 18
Thread: DigitalFX 3.0 Gauge problem
    Aug 2006
    whenever i go to the "Gauges" menu my MPH\KPH is just a white square. why is that? how do i fix it? is it fixable?
    the square is just a blank square but the little needle is there and moves like it should
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    here we go with the white box...
    tja
    tja is offline
    Aug 2005
    sydney, australia
    you have to unistall xp and reinstall from scratch.
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    well i never heard about this white box thing.......
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Mar 2006
    Colorado, but Canadian!
    Well put answer here: what is wrong with my logo
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2006
    Quote Originally Posted by tja View Post
    i'm not a retard, but thanks for trolling and your useless response kthx
    Quote Originally Posted by 2k1Toaster View Post
    thank you
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
    x10
    x10 is offline
    Constant Bitrate x10's Avatar
    Mar 2004
    Pittsburgh, PA
    Just install the latest flash from adobe.com....that should do the trick
    Oct 2007
    Quote Originally Posted by iNcArCeRaTiOn View Post
    You asked the stupid question not him! You deserved that answer, try using the search sometime or try reading the thread you downloaded DFX from.
    Not only that why post a whole new thread? why not just use the DFX feedback?
    --me
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    wow! this guy been here since 2006 2 yrs later and he still wondering why white box is there
    Flash my friend Flash play around with Flash im sure you fix the prblem
    EL CAMINO's Avatar
    Jul 2005
    next is the red ball...
  1. DSATX problem, not power switch problem!
    By VThokieME in forum Power Supplies
    Last Post: 05-04-2008, 01:22 AM
  2. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  3. Replies: 22
    Last Post: 03-09-2005, 11:27 AM
  4. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 12:13 PM
