Results 1 to 10 of 14
Thread: Skin Wont Change
    Feb 2008
    Skin Wont Change
    Hi,
    I looked about but can not find an answer to the following, easy for you guys I know.
    Why when I use the skin editor and change a menu in the BMV2 save it etc, then when I open road runner the menu hasnt changed?
    I checked the location of skin to open and edit and the skin RR is using and both one and the same.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    are you changing the actual images or the skin elements (commands/labels/etc.). Describe what ur attempting to change and it'll help to provide a solution.
    Live mp3Car Facebook Chat
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I know from experience that if you don't go File, Save, it doesn't save automatically on exit.
    Feb 2008
    Hi,
    what I was doing was changing the RDS station name in the radio skin. I moved it and made it larger and clicked file, save and got the message, skin saved etc.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i remeber from past editors if its not saving to your skin file ,have alook in the skineditor folder for a temp skin file that will be the 1 you just saved.
    check your save path in the settings/editor settings tab in editor
    mine says
    C:\Program Files\Road Runner\Skins
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Feb 2008
    Hi Again!
    Just checked, yep mine says:
    C:\Program Files\Road Runner\Skins.
    Also copied the settings txt:
    ObjectColor=16777215
    ObjectBorder=2
    SelectedObjectColor=65535
    SelectedObjectBorder=4
    EnableMouseOver=True
    EnableMouseDown=True
    EnableFlashPlayback=True
    ENABLEAUTOUPDATE=True
    RRSkinPath=C:\Program Files\Road Runner\Skins
    EnableSaveConformation=True
    PropertyBoxWidth=6065
    LWO_1=
    LWO_2=
    LWO_3=
    Feb 2008
    Any ideas?
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    To actually make the label larger you need to define a font size. Simply dragging the label box larger in skin editor will not make the label any bigger.
    I think that is your issue/
    Feb 2008
    Quote Originally Posted by blk02si View Post
    HI<
    I did change the font size, the size of the label, moved the lable, clicked save skin, message "saved skin" appears but when I shutdown and restart rr, nothing has changed no matter what I do to the skin.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by the_big_1 View Post
    HI<
    If all else fails...there's always notepad...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. Step-by-step skin change
    By black06stang in forum Road Runner
    Last Post: 05-07-2006, 10:49 PM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  5. how do i change the skin
    By deathduck in forum FrodoPlayer
    Last Post: 09-08-2004, 11:09 AM
