This is an outstanding skin! The animation, the layout, the colors and configurability, is overwhelming.
Noticed a couple things though. The readme.txt didn't give me any hint that I had to copy my personal backgrounds to the skinpath - took me a few minutes to figure it out. There's no blank page, i.e., header/footer and nothing in between letting the background show through (maybe a press and hold option on the minimize button). When in the playlist mode of the audio player, hitting the vis button floats the vis cause there's no A,,,,,, to embed it. Now that internet
radio is available via audio player, can you replace your TAGTITLE labels with TRACKNAME so I can see the song and artist name sent via the stream to Winamp? When exiting from menu.skin, if I change my mind and hit the ENTERTAIMENT button - nothing happens; then I hit the TOOLS button and the tools screen moves in under the exit menu. Same if I exit menu skin, hit TOOLS, then ENTERTAINMENT - exit menu stays on top.
Love the Fusion Brain page, but How do I change the buttons from toggles to momentaries, i.e.,
DIGITALOUT#TOGGLE (where # is digital out port 0-11)- toggles the port based on its current (connected/disconnected) state
DIGITALOUT#SWITCH;SECONDS(where # is digital out port 0-11 and SECONDS is number of seconds u wish to leave port ON)- turns the port on for specified number of seconds. PLEASE note seconds are NOT exact +/- 1.5 seconds
This may require an addition to the skin.ini.
Man this looks good! Kudos!
