I am trying to write a plugin that can talk to my car's built in Sirius radio. It is a Dodge Charger and I have a device that can communicate with the car's CAN bus. I have successfully written some software that controls both the digitally controlled amplifier, and the Sirius radio.
The problem is that I now need to write a skin to control my software. I am basing the skin on the DFX 3.0 skin.. (JohnWB... this is an awesome skin!!!). I think RR is specially set up to use the 1 Sirius radio, and no others... I'm guessing that since I don't have that radio, the channel list doesn't populate. So I started to make my own Custom List. I filled it with my custom information. I want to display the channel art that is in SRArt directory. So I created an indicator that uses a FILE:$filename$ When the user clicks on the custom list, the variable $CANSIRIUSTEMP$ changes to the filename of the channel's image that is selected. This works..... just not all the time. For some channels, it always works... other channels don't work until i restart RR.
Any ideas? I'm new to skinning, so I could be doing something completely wrong....
Here's the code in the skin
Thanks in advance.......Code:/dodgesirius.skin I01,543,7,242,92,"FILE;$CANSIRIUSTEMP$:A" /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed IL,CL,transparent.bmp,sel.bmp,end.bmp,2,50,80 /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name SC01,216,164,511,341,#DFX1R#,#DFX1G#,#DFX1B#,#DFX1R#,#DFX1G#,#DFX1B#,255,#DFX1R#,#DFX1G#,#DFX1B#,255,5,TRUE,20,"Arial Narrow:B" S02,747,148,36,356,449,91,36,368,V,01,"Sliders\Pointer.png",12,"CLSLIDER","" /ExecTBL.ini "LOADSIRIUSLIST","CLCLEAR;ALL||CLLOAD;C:\Program Files\Road Runner\SRArt\Sirius Channels.txt||SETLIST;$CANSIRIUSCHANNEL$",DodgeSirius.skin "ONCLCLICK","SETVARBYCODE;TEMPVAR2;CLPOS||SETVARBYCODE;TEMPVAR;CLTEXT$TEMPVAR2$||SETVAR;CANSIRIUSCHANNEL;$TEMPVAR$||SAVETOSKIN;CANSIRIUSCHANNEL;$CANSIRIUSCHANNEL$||SETVAR;CANSIRIUSCHANIMAGE;$CANSIRIUSPATH$$TEMPVAR$.gif",,DodgeSirius.skin
R
