Results 1 to 8 of 8
Thread: I need to know if you can use Excel and MS Access in RR?
    Jul 2008
    Lee's Summit
    I'm looking to create reports on my car. I would like to store the data into MS Access and display it using Excel in the RR application. Is this possible? I have done some searching but don't really find much on it.
    Troy
    Batmaninls
    www.evorbust.com
    Feb 2006
    Just embed Excel like any other external app?
    Jul 2008
    Lee's Summit
    There is a Application object but no way to point it to Excel. Should I use a different type of object in the editor?
    Please let me know thanks
    Troy
    Batmaninls
    www.evorbust.com
    Jul 2008
    Lee's Summit
    Found what I need kinda...
    Well this works it's not what I was after but its a good start. I really wanted it in the window of the of my skin like the browser is.
    "LOAD;Reports.skin;Reports;C:\Program Files\Microsoft Office\OFFICE11\Excel.exe;Reports"
    Can anyone help me out there...
    Making it stay in the RR skin area..
    Batmaninls
    Batmaninls
    www.evorbust.com
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    check out the faq section on embedding applications. should work with all applications including ms excel and access
    Jul 2008
    Lee's Summit
    Will do thanks for the advice.
    I will check into that today thanks.
    Batmaninls
    www.evorbust.com
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    1) You don't have to make a separate skin for them, you can just add it as an item in your LAUNCH folder and then run them from that skin.
    2) If you do want to make a custom .skin for them, then you were on the right track, you just need to get the window name right. It's not "Reports". It's probably "Excel" or if you want it to autoload a file then you add that filename to the command line and then the window name would probably be "Excel - Reports" or something like that.
    -InfinitiPC
    Jul 2008
    Lee's Summit
    Yes I wanted it to come up on the .skin its self. I have a .skin named Report.skin and when I click a button I wanted it the launch Excel onto the .skin file. Like you can have the browser do. It's ok for now because I'm working on another part of the .skins this evening. I'm learning about what makes things tick for my gauges. But if you know of a way to make it open on just the .skin please advice.
    Troy
    Batmaninls
    www.evorbust.com
