it worked pretty nice i liked it alot i will def use this... i will keep on testing it for a while as i like the sirius and the presets :) those are nice
Printable View
any body having problems with the skin?
any requests for add ins?
I assume no news is good news but I find it hard to believe that I caught every bug before I released it...
I played with it a bit today. I like it a lot.
Not quite sure how to raise the volume though, when I push the knob o the left it only reduces the volume.
Not exactly sure what the menu button's exact function is either.
Outstanding job on the skin X10, it looks very nice!
Couple of small bugs, when in the Playlist screen, the navigation button does not work, and in navigation, the Full Screen buttons does not work. It brings up the button in the top right to exit FS, but the screen itself remains the same.
Have a look at my skin where you got the EXIT_FS.exe. You can see on the button code for Full Screen (in the External_Gps.skin), how I call a totally empty skin and embed iGuidance in it, then the EXIT_FS.exe is fired so there is a way to go back a screen. The EXIT_FS.exe itself does not make iG go Fullscreen, it just acts as an overlay, that when pressed sends RR the ESC command to go back to the previous screen.
I figured out the volume dealie this morning. I think the push points are a little small. Although I use a rotary controller most of the time.
The Sat and Ter indicators aren't working for Sirius. And same issue that John's having with the full screen.
There also seems to be about 4 playlist screens for sirius and it's a little confusing.
Attachment 51270
Here are the fixes for the GPS Full screen issue as well as the GPS button not working in the Audio Playlists chooser skins.
The ExecTBL.ini file has also been updated....
As of right now, I am working on fixing the Satellite and Terrestrial Signal Strength Indicators as well as implementing XM into the skin.
Good deal. I've been using the skin all week. Keep up the good work.
I've noticed that if you go to the sirius screen and then switch back to the main menu that the channel art is stretched. It will fix it self if you push one of the pre-set buttons on the bottom.
Also, how do you change the Sirius pre-sets? (preferably without editing the skin files.)
Nice skin. Very OEM looking. :)
Two suggestions...HD radio and an option to choose between standard and database, like John did with his skin. :)
