Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: .:[ x10's GMLAN ]:.
  1. #11
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    it worked pretty nice i liked it alot i will def use this... i will keep on testing it for a while as i like the sirius and the presets those are nice
  2. #12
    x10
    x10 is offline
    Constant Bitrate x10's Avatar
    Mar 2004
    Pittsburgh, PA
    any body having problems with the skin?
    any requests for add ins?
    I assume no news is good news but I find it hard to believe that I caught every bug before I released it...
  3. #13
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I played with it a bit today. I like it a lot.
    Not quite sure how to raise the volume though, when I push the knob o the left it only reduces the volume.
    Not exactly sure what the menu button's exact function is either.
  4. #14
    x10
    x10 is offline
    Mar 2004
    Pittsburgh, PA
    Quote Originally Posted by Machinehead View Post
    top part of the left knob is to raise the volume...the bottom half of the knob will lower it...
    the MENU button just always takes you back to the Main Menu of the skin...
  5. #15
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Outstanding job on the skin X10, it looks very nice!
    Couple of small bugs, when in the Playlist screen, the navigation button does not work, and in navigation, the Full Screen buttons does not work. It brings up the button in the top right to exit FS, but the screen itself remains the same.
    Have a look at my skin where you got the EXIT_FS.exe. You can see on the button code for Full Screen (in the External_Gps.skin), how I call a totally empty skin and embed iGuidance in it, then the EXIT_FS.exe is fired so there is a way to go back a screen. The EXIT_FS.exe itself does not make iG go Fullscreen, it just acts as an overlay, that when pressed sends RR the ESC command to go back to the previous screen.
    My Fiero Build Thread
  6. #16
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by x10 View Post
    I wish it had XM. I guess I will change the sirius over.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  7. #17
    Jun 2007
    I figured out the volume dealie this morning. I think the push points are a little small. Although I use a rotary controller most of the time.
    The Sat and Ter indicators aren't working for Sirius. And same issue that John's having with the full screen.
    There also seems to be about 4 playlist screens for sirius and it's a little confusing.
  8. #18
    x10
    x10 is offline
    Mar 2004
    Pittsburgh, PA
    Attachment 51270
    Here are the fixes for the GPS Full screen issue as well as the GPS button not working in the Audio Playlists chooser skins.
    The ExecTBL.ini file has also been updated....
    As of right now, I am working on fixing the Satellite and Terrestrial Signal Strength Indicators as well as implementing XM into the skin.
  9. #19
    Jun 2007
    Good deal. I've been using the skin all week. Keep up the good work.
    I've noticed that if you go to the sirius screen and then switch back to the main menu that the channel art is stretched. It will fix it self if you push one of the pre-set buttons on the bottom.
    Also, how do you change the Sirius pre-sets? (preferably without editing the skin files.)
  10. #20
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Nice skin. Very OEM looking.
    Two suggestions...HD radio and an option to choose between standard and database, like John did with his skin.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. Anybody done anything with CANBUS / GMLAN?
    By dmurray14 in forum General Hardware Discussion
    Last Post: 10-04-2005, 10:36 AM
