Results 1 to 5 of 5
Thread: Help - ExecTBL
    Dec 2006
    Help - ExecTBL
    Hi guys,
    Trying to get Sygic Drive running in Night_Apple Skin and it uses a ExecTBL file.
    If I use the following it works but soon as I add switches it does not.
    ORDER UNDER MENU-BUTTONS
    /path .GPS.............................................. ...........{ path to your gps application }{ window title}
    "Sygic","LOAD;Sygic_FullScreen.skin;RUN;C:\drive_x p\drive.exe"
    This works, but this does not....
    "Sygic","LOAD;Sygic_FullScreen.skin;RUN;C:\drive_x p\drive.exe -r800x480 -no-safety,1
    It does not work.
    How do I get switches to work in a ExecTBL.
    Cheers
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Try using "|" instead of "-"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Firebird2 View Post
    Hi guys,
    Cheers
    You left off a quote at the end of the command
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    You may not be able to have command line arguments in a button command. Create a batch file like drive.bat
    put this in it.
    Quote Originally Posted by DRIVE.BAT View Post
    C:\drive_xp\drive.exe -r800x480 -no-safety,1
    Then put this in your extbl.ini
    Quote Originally Posted by EXTBL.INI View Post
    "Sygic","LOAD;Sygic_FullScreen.skin;C:\drive_x p\drive.bat"
    Aug 2006
    West Allis, WI
    if you are trying to embed an app use this example from the skincommands.txt
    LOAD;EXTERNAL_GPS.SKIN;Destinator GPS;Destinator3.EXE;Destinator
    Command;Skin file;Window Name;Command Line Command;Voiced Text
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. iTunes
    By CoryF in forum RR Plugins
    Last Post: 10-25-2007, 07:50 PM
  3. ExecTbl not working on resume?
    By wywywywy in forum Road Runner
    Last Post: 09-29-2007, 09:08 AM
  4. How to use Girder with Road Runner
    By contaygious in forum RR FAQ
    Last Post: 07-18-2007, 07:20 AM
  5. ExecTBL Commands for Video_Player.Skin
    By Prem in forum RR Bug Tracker
    Last Post: 08-11-2005, 02:56 PM
