Page 18 of 31 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #171
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Thanks for noting that. New version coming very soon, with corrections and new graphics.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #172
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    Contrary to the above suggestion, to get GMPC to actually load I had to use the following setting:
    Code:
    garminpath=C:\GarminMobilePC\Que.exe
    So i guess your instructions are correct. Your comments above confused me though. I suggest for anyone having trouble getting the garmin app to load, check the garminpath setting. Mine was incorrect and this was causing my problem.
    RR seems to be closing GMPC on exit so all is working well.
    Simplistique skin
    RR 13/12/07
    GMPC 5.00.50
    Next step... I want to ditch all the overlay buttons and just have one button that turns the OSK on and off. I run my GPS apps full screen, and have physical byttons on my LCD for next/prev/vol+/vol-/menu
    I assume I can just jump in photoshop and remove the buttons from the PNG files and then their definitions from the skin files?
    Thanks for this App by the way. I look forward to not using destinator any more
  3. #173
    May 2007
    Lakehood, CO
    What I meant to say was that there's a new version that will include pictures, rather than text only. It will be a lot easier to follow, and should prevent a lot of the issues posted here. My free time has been dedicated to finding a job, and now that I've found one, my free time will be taken up with work, so getting this much needed update has been long overdue. Also, my skineditor is trying to install AutoCAD, so I'm having fun troubleshooting that too.
    You should be able to load up Photoshop and chop off the buttons you won't use. But I'll be releasing the PSD's with the new update, so it will be even easier to edit everything. Then you'll want to remove the definitions in the .skin files.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  4. #174
    Jul 2004
    AUSTRALIA
    thanks mate. Any chance of getting a copy of the PSD files off you early? Would make editing the images a lot easier
  5. #175
    May 2007
    Lakehood, CO
    New version uploaded, as well as user guide and PSD's on first post.
    Please let me know if there are any issues with this version.
    The user guide will need either powerpoint viewer (free) or powerpoint (not free) to be viewed.
    The PSD's will require these two fonts to work:
    JC Auto Design's CarPC.ttf
    and
    Bank Gothic Medium
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  6. #176
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Those are VERY clear instructions in the ppt file. Thanks for posting them. However, slides 6 and 7 are identical, which means the special instructions slide for skins like DFX4 aren't there.
    Hope you can add them, I love this overlay and am looking forward to using it with both DFX and LSX skins!
    Want to:
  7. #177
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Very well done! It feels like it's missing an ending tho, sort-of like "close and save all changes - reload your skin" but that's minimal.
    The answer to the next questions should be
  8. #178
    May 2007
    Lakehood, CO
    The actual slide images are in the User Guide folder, and labeled, so while I fix the slideshow, you can view the instructions by opening the Special Instructions.png.
    I may add a slide in between 6 and 7 that has shows how to test to make sure it works. And a credits slide too, with a link back to this thread possibly...
    Basically, any question asked in the 170+ posts in this thread are answered in the User Guide. If I missed something (not impossible) then I'll add it.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #179
    Jul 2004
    AUSTRALIA
    wow - great work!
    I have modified the skin as I mentioned previously, but I cant get the buttons to work.
    Is there any reason this code shouldn't work? I am running 800x600
    Code:
    RoadRunner Skin
    RRScreen gmpcol
    /POSX=000
    /POSY=000
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B05,0,1,300,50,"X_OVERLAY||WAIT;0.5||GMPCOSK",
    B01,650,1,149,40,"X_OVERLAY||EXIT",
    END
    I have chopped everything out of the gmpc600.png image, except the bar along the bottom (wasnt sure what it was for so left it there)
    I have never played with this overlay stuff before. If the image is transparent at the area whre the button is defined, will the button still work? I suspect this is my problem. I judst want an invisible button over the GARMIN logo so when i click it it switches the OSK on...
    I have attached my modified skin files. Thanks for your help.
    Attached Files Attached Files
  10. #180
    May 2007
    Lakehood, CO
    The way the overlay works, the clickable area must not be transparent. So you would have to have SOMETHING there.
    The bar along the bottom was just to hide the hotkey designations, but I left it out of the new update. I've included some .PSD's if you want to chop those up, just make sure there is something under the button you want.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. Replies: 12
    Last Post: 09-23-2008, 08:09 PM
