Page 2 of 31 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #11
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Can't get it to work properly. When I use this line:
    "GMPC","LOAD;GMPC.skin||RUN;$garminpath$;!CDP",GMP C.skin
    Nothing happens, only the overlay shows. No GMPC skin and Garmin doesn't start.
    When I use:
    "GMPC","RUN;$garminpath$;!CDP"
    Garmin loads but at the wrong resolution and the overlay shows but not in the right place as Garmin isn't at 800x600...
    When I use "GMPC","LOAD;GMPC.skin"
    The GMPC skin loads...
    So it's only when both are used in the same line none of them load. Individual they work.
    Any ideas?
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  2. #12
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    I think you probably have done this, but have you set garminpath correctly in rr.ini?
    GMPC should fill the skin dimensions if this is set up correctly.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #13
    May 2007
    Lakehood, CO
    Quote Originally Posted by Fiberoptic View Post
    I blogged about this on the home page. Let us know if your bandwidth gets out of control and we can host the rar. Very cool.
    I have plenty of bandwidth, but will probably dual host it with the forums here.
    One thing to note with the blog is that this wasn't all my doing, I had ThunderStick and ElCamino's help, and I think credit should be shared. All I basically did was the graphics, TS did the script, and ElCamino did the overlay plugin.
    Edit: btw thanks for the recognition! It's nice to be noticed.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  4. #14
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    agreed!!
  5. #15
    Sep 2006
    Belgium
    Quote Originally Posted by monkeyracer View Post
    Yes the path is set correctly. It also runs when just using this part oft the line:
    But at the wrong resolution. And when trying to use the entire line, nothing happens. Only the overlay loads but not Garmin or the GMPC skin. I don't get it. It should work, I know, but it doesn't...
  6. #16
    May 2007
    Lakehood, CO
    did you copy over the 800x600 files?
    if so, then I will have to look at it a little later today, I use 800x480, and that would work fine, maybe I missed something getting it into the 600 version.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  7. #17
    Sep 2006
    Belgium
    Yes, the files are copied over. They also pop up when I only use this part of the line:
    Also the overlay works correctly at 800x600.
  8. #18
    Sep 2006
    Belgium
    Ok, I think I found a workaround that seems to do the trick.
    In Exectbl.ini I've split the "GMPC" command and made a command called "RUNGMPC"
    Now my Exectbl.ini looks like this:
    Code:
    "GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin"
    "GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.skin"
    "X_OVERLAY","SENDMSG;ElcosMenu;Exit"
    "RUNGMPC","RUN;$garminpath$;!CDP"
    In my skin file it now looks like this:
    Code:
    B11,400,533,100,67,"GMPC||GMPC_OVERLAY||RUNGMPC",""
    Now everything seems to work except for the fact that the GMPC.skin isn't transparent. It's red instead?
    Since I didn't install any maps yet I couldn't check how and if the keyboard works. But I by the looks of it now this is gonna be a great little add on! I wanted to put Garmin Mobile PC in the car for quite some time now but the lack of a keyboard always kept me from doing it. I think my doubt's are over now.
  9. #19
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Cool Thank You MonkeyRacer!
    While my setup isn't used on a daily basis( I live less than 2 miles from work ) I love my GMPC and have been waiting and hoping someone (with more know-how than I) would work on a solution to this problem. John has done well with DFX 4 to get Garmin into RR but, you including an OSK (with the help of others) is a great stride toward getting GMPC to work like some of the other satnav systems. Although I haven't had a chance to try your mod I hope you will continue (as well as others who add to RR) to get this to work.
  10. #20
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    hi,
    any support for 1024x600?
  1. Replies: 12
    Last Post: 09-23-2008, 09:09 PM
