Page 23 of 31 FirstFirst ... 13141516171819202122232425262728293031 LastLast
Results 221 to 230 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #221
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    Try my skin maybe that would work better on Vista
    http://forums.fluxmedia.net/plugin-d...-dev-beta.html
    If it works fine i will do the custom version for RR too.
    To install add the button that will run my app... it will automatically launch the GMPC for you
    Automotive LED Headlight Module High Power VS HID NEW
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  2. #222
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    well I triple checked everything..I have installed this 3 times on a XP machine no problems. So I presume that this is a Vista deal..I even ran it in compat mode just in case no luck) anyone out there whom is running this overlay on Vista without hiccup's? heres my setup
    Vista Ultimate All updates
    elcosmenu 1.3
    Riderunner March update fresh install
    Dfx 4
    800x600 resolution
    thanks Temp.. I try out tomorrow Im frustrated 2nite..I'll let ya know
    ***I attached my setup files... renamed the files to upload but there original .ini's or .skin
    Attached Files Attached Files
    Did it.. Done it... now I got to keep the neighbors kids away!!
  3. #223
    Jun 2008
    Illinoise
    I first had vista on my machine with this problem. Switched to an N'Lite'd version of xp and problems went away.
    Was told by RR experts that RR is not meant for Vista yet.
  4. #224
    Jun 2007
    RR works fine on vista
  5. #225
    Aug 2008
    Roadrunner works fine on mine as well, infact seems faster this is the only problem i seen so far. I'm hoping it's a easy fix otherwise back to XP.. gottas have my garmin overlay...lol
  6. #226
    Mar 2009
    I am having problems where garmin won't open. If I open garmin first, minimize it, and then go into road runner, it will work fine, but it can't open it on its own. It's just stuck on the loading navigation screen. I triple checked all of the instructions and even uninstalled road runner completely and installed it again. Any ideas?
  7. #227
    Aug 2008
    reply with your exbl, rr.ini. and menu.skin files please
  8. #228
    Mar 2009
    I wasn't sure how to attach them, so I just renamed them all to .doc. Hopefully you can just change the extension back and they should work.
  9. #229
    Aug 2008
    hey the exbl file you posted is that the one inside RR root dir or in DFX directory?
  10. #230
    Aug 2008
    nevermind i see your not using the dfx.. the exble is that all thats listed or did you clip it.. i think you got it in the wrong execbl location..not sure if you got this in the skins directory or RR directory.. the one you posted looks too basic to be the skins execbl.. that would certainly cause you not to load within your skin..
  1. Replies: 12
    Last Post: 09-23-2008, 08:09 PM
