Page 25 of 31 FirstFirst ... 1516171819202122232425262728293031 LastLast
Results 241 to 250 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #241
    Mar 2008
    Russian lanage please++++
    RUSSIA - WINER!!!
  2. #242
    Feb 2008
    I'm using dfx4 and trying to get the Garmin overlay to work, the program fires up perfectly but i get no overlay at all i am using lord nicons instructions and have gotten a the button to fire up garmin but i get no overlay at all then i have to shut down garmin and press esc on my mini keyboard to get back the the main skin i have attached my config files to get look at i hope there is just something simple im missing.
    Also i am using the 1.3 ver of Elcomenu so it works with riderunner
    Exectbl.txt
    rr.txt
  3. #243
    Feb 2008
    Nvm got it working!! Lord Nicons has some spaces where there should not be.
  4. #244
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by Xargon321 View Post
    could you explain a little more.... what has some spaces where there should not be?
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  5. #245
    Feb 2008
    "GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL .skin" ---->GMPCOL .skin
    "GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.ski n" -------->GMPCOSK.ski n
    "X_OVERLAY","SENDMSG;ElcosMenu;Exit"
    "GMPC","LOAD;GMPC.skin"
    "RUNGMPC", "RUN;$garminpath$;!CDP"
    I think it is a forum glitch because even just posting it make more errors in the code more spaces where there is not any when its typed out
    Quote Originally Posted by LordNikon View Post
    Sorry guys, i should have posted what changes i made to get it to work...
    Ok, for getting the overlay working in DFX 4.0...this is what i did:
    Firstly, to make sure that you are getting Garmin Mobile PC to load, make sure you have these 2 lines in RR.ini:
    gpsname=Garmin=C:\GarminMobilePC\Que.exe
    garminpath=C:\GarminMobilePC\Que.exe
    Then in your DFX4.0 skin folder, find Exectbl.ini and you need to make a few changes:
    1st: Find the ------Embed External Applications------- section and make sure the Garmin/Gps line says this:
    "Garmin","LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\G arminMobilePC\Que.exe;!CDP_FIELD_WND"
    2nd: Find the ------Dynamic Menu Buttons------ section (down the bottom of the file) and make sure you have this line:
    "MyApp53","GMPC||GMPC_OVERLAY||RUNGMPC"
    3rd: Find the ----GPS Section By BlueZX3 & JohnWPB----- section (VERY bottom of the file) and then add these 5 lines:
    When i was looking at how all the files talked to each other in DFX4.0, i noticed that it was all done in the ini's and not the skin files like the other skins. So if you have made any changes to the skin files, restore them to original, make the changes i listed above and it *should* work...did for me (wonderfully i might add)....and i am very grateful to Monkey for initially creating this...
  6. #246
    Jun 2008
    Illinoise
    Dam, just spent 5 hours trying to figure out why the overlay wouldn't open when I hit the GPS button on DFX4.
    Numbnutz me had the overlay open command on "B06" which is actually the 5th button. LOL
    Moved it to "B07" , and all is well.
    Now to conquer voice control!
  7. #247
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    i have voice prompts in my skin for CF
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  8. #248
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    what you mean voice prompts? Garmin comes with its own.
    Did it.. Done it... now I got to keep the neighbors kids away!!
  9. #249
    Jun 2007
    New York
    you need to mute music to hear them
  10. #250
    Jun 2008
    Illinoise
    Quote Originally Posted by tempgp View Post
    Not for me, my voice prompts in GMPC for turn-by-turn are the same volume as the music I am listening to.
    The only prob I have is when I am using the stock radio or disk changer, and the audio from the pc is switched off.
    Working on a fix for that, involves a line level output mod to my stock HU that would input into the carpc.
  1. Replies: 12
    Last Post: 09-23-2008, 09:09 PM
