Page 26 of 31 FirstFirst ... 16171819202122232425262728293031 LastLast
Results 251 to 260 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #251
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    i guess your ears are good =) sometimes you cant hear the directions when music is on....
    for second part you can get line amp chip and connect it to reley... it will switch sources once pc sound output is detected... or you can use phydgets to do that too
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  2. #252
    Jun 2008
    Illinoise
    Quote Originally Posted by tempgp View Post
    I will look into that. My HU has no Line out, so the mod I am doing is board level re-routing of the audio signal, detouring pre-amp to run through the PC first. This may or may/not allow me to remove some/all of my HU controls on my dash. See: 05 Murano posts to understand how the dash is laid out.
    So much work, so little time.
  3. #253
    Jun 2007
    New York
    why u need line out on HU? You would look for line in instead =) Either way most of the time there are no AUX ports in new cars (hmm or in any HUs that are stock or expansive)
    Link you gave me is 404 not found.... but what I did in my car i cut the wire going to HU from the CD changer and when I want to hear the pc I turn to CD and switch the source, similarly i can switch back to PC. This would work on any car that is not using fiber optics (not sure about murano system) Then since i have manual switch I can add PC controlled relay to switch back to PC is GPS talks...
    Im not doing that though as I'm planing to get rid of HU completely.
  4. #254
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i'm having a problem with the overlay throwing the following error and closing.
    "Line -1: Error: Variable used without being declared."
    this usually happens when hitting the osk button, but sometimes it can happen when exiting the osk. it might be worth noting that i am running windows 7 64 bit. i don't believe i had this issue running xp 32 bit.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  5. #255
    Jul 2009
    B.C., Canada
    I'm running W7 64 bit and have never seen the error, so I can't really help you to fix it but I can tell you it's not OS specific.
  6. #256
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    i have this problem on 3 different machines for me. also it's an autoit error which i forgot to mention. it seems like a timing thing. it's very unpredictable when the error occurs. i can duplicate it with different skins too.
    if it's not os specific then the only other thing i can think of is hardware. i have two carputers both running nvidia chipsets. my dell xps m1530 laptop has nvidia graphics but not sure about the rest of the motherboard. something else i noticed after i upgraded to my current setup, the sendkey buttons that i had working for my iguidance skin started having trouble. sometimes they would work and other times not. i could hit the button 10 times and maybe 2 or 3 times it would work. i had to add a wait;1 to the code so that it would work reliably. i chalked it up to my new c2d cpu being too fast or something stupid like that.
  7. #257
    Sep 2008
    Western Australia
    Quote Originally Posted by Tical84 View Post
    Quick question for you as you're also running Win7. Do you find that the Overlay doesn't stay on top as long as Explorer.exe is running? Ever since I upgraded to Win7 I've been having this issue. Somehow Explorer causes the Overlay to lose focus and GMPC will be on top of the Overlay. If I kill Explorer then everything is fine and it works as it should.
  8. #258
    Jul 2009
    B.C., Canada
    I just went to play with it a bit and I can say that I don't have any problems with the overlay not staying on top. I also turned the OSK on and off 20 or so times and never got an error. I can't duplicate any of these problems.
  9. #259
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by zillacles View Post
    I had the same issue. My workaround was to autohide the taskbar and have an autoit script on the desktop that moves the mouse to show the taskbar when needed. I believe the issue is that win7's taskbar is always on top and makes the gmpc window open shorter than specified by the skin. RR then resizes gmpc and leaves it on top. It may not be accurate but that's my theory.
    I have no clue on the error I'm getting. I'm just hoping the next version has an osk built in and uses a regular window that we can embed.
  10. #260
    Jul 2009
    B.C., Canada
    Right now I'm not running mine full screen because it's still connected to my test screen (an old CRT monitor). That may be why I'm not seeing the overlay on top issue. I'll have to test that one out when I get home from work.
  1. Replies: 12
    Last Post: 09-23-2008, 09:09 PM
