Page 27 of 31 FirstFirst ... 171819202122232425262728293031 LastLast
Results 261 to 270 of 309
Thread: Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
  1. #261
    Sep 2008
    Western Australia
    I just realised that the Elcosmenu included with the OSK from the first post isn't the newest one. So I copied over the newest version and now it stays on stop when starting GMPC. However it does disappear when getting to the part where you enter the street name. I haven't yet updated to the Feb RR edition which may fix this as it says it handles the start button/taskbar in Win7 better.
  2. #262
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    we just finishing porting our version of GMPC Plugin to CF3.it not only overlies properly but also detects audio directions and mutes the music while directions are spoken.
    We can do the same port for RR so you guys can engoy it on RR front end too =)
    Let me know if you interested
    check Centrafuse formums for details
    http://forums.fluxmedia.net/plugin-d...e-prompts.html
    or www.tempgp.com
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  3. #263
    Sep 2008
    Western Australia
    Actually muting/lowering the volume of music when GMPC speaks is possible in RR too. Some of us have it working using NavMute (http://www.mp3car.com/vbulletin/garm...reat-gmpc.html)
    Actually one thing is, have you noticed whether GMPC has a really low volume compared to other programs like Winamp?
  4. #264
    Jun 2007
    New York
    will look at that link, volume issue is easy to fix to =)
    i mean it will cost me sat $200 do do 1 more driver for garmin, but if there are anough ppl to lijne up and put in few buks i think we can do special library for amplifing virtual audio chanel for garmin
  5. #265
    Sep 2008
    Western Australia
    Oh, well I was wondering if you had noticed that issue or if it is just me. I saw another guy on here was playing around with the Garmin API the other day, that looks interesting too.
    Updated to the latest RR version which actually hides the W7 taskbar, but the overlay still randomly disappears from time to time if explorer is running. Not that big a deal I guess since I'll start Windows straight into RR instead of explorer.
  6. #266
    Jun 2007
    New York
    I did have problem w. audio levels myselve just got used to low volume directions, but we had project for other clint to manage audio streams. so we can recompile it to suit needs of amplifying garmin audio levles.
    As to overly, our new engine has extreme stability ;-)
  7. #267
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    the error i am getting is caused by the labels that i've included in my skin. when i comment out the labels, the error does not appear. i had tried turning off the timers that update the labels first but that made no difference. only when i get rid of the label code does the error go away. anyone have any ideas?
    @tempgp a rr port would be awesome. would it be possible to have music player commands and label support like the screenshots above?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  8. #268
    Jun 2007
    New York
    yep thing like that should be easy job...
    we will ned new brain to work w/ RR though
    well, let me see what i can get... if i rekease our port you will do the marketing for it ;-)
    And I will also need some one else help on skininfg and figuring out ways to add buttons to launch app (I havent been conding for RR for more then a year now)
  9. #269
    Jun 2002
    Malaysia
    Quote Originally Posted by kuo View Post
    i'm having a problem with the overlay throwing the following error and closing.
    "Line -1: Error: Variable used without being declared."
    this usually happens when hitting the osk button, but sometimes it can happen when exiting the osk. it might be worth noting that i am running windows 7 64 bit. i don't believe i had this issue running xp 32 bit.
    I also get this error many times. I run this overlay with Windows MicroXP and RoadRunner.
    It will kill off the overlay, and leave me with a screen then I can't back out of. Means I am stuck with the "choose street or poi" page and I can't get back into RoadRunner or go back to GPS. The only way out is to hit the power off button and reboot (as I don't have a keyboard in the car)
  10. #270
    Jun 2002
    Malaysia
    Quote Originally Posted by jessekilner View Post
    what skin you using? if your talking about what i think you are that would'nt be triggered by overlay it would be..
    **Open the rr.ini file in Road Runner's root folder and ensure Fastmode=-1 is in there. If not add it, if its another value, change it to -1
    Post a screen shot..
    I am also having huge resource problems. It seems the entire RoadRunner is slow ever since I installed the GMPC Overlay.. When I try to type in some letters, it takes about 3-4 seconds for that letter to appear.. but I can type quickly if I am confident I dont make any errors, and after about 5 seconds the entire street name will appear.. But the problem is, it also affects playback. If I hit Music on RoadRunner, and I try to double-click to switch to another song, it takes about 3 seconds to start playing the other song.
    I would like to confirm if its the GMPC Overlay problem but I don't know how to uninstall it, LoL. Is it alright if I just remove the RUNGMPC GMPCOverlay line? Will that "temporarily" uninstall it so I can check if it has any effect on speed?
    I don't know what version of ElcosMenu I have (how do I check?). I believe I have the 1.25 because I saw the note in the first post when I installed it. Which version is the fastest one?
    I am running RoadRunner with Rob's BMW E36 skin, on an EPIA M10000 with 1GB RAM on a 40GB notebook harddisk (4200RPM).
  1. Replies: 12
    Last Post: 09-23-2008, 08:09 PM
