i'm running win7 64bit in my car and it works fine. i forgot that i had the osk toggle button coded in exectbl.ini with a "||activate;Garmin Mobile PC" but your way is much cleaner.
Cheers for that, seems to be working fine on my WinXP virtual machine. Hopefully works the same on the Win7 carPC. I edited the scripts slightly to suit the SypheR skin which I'm currently using (the positioning of the window). I made the paths to the executables relative so there is no need to edit the path in the script as long as they are in the same folder as each other. Also, I made it set focus back to GMPC when the OSK is toggled so you don't have to click back into GMPC after opening the OSK to type something.
openOSK.au3
Code:#include <WindowsConstants.au3> Run("FreeVK.exe") WinWait("[CLASS:TMainForm]") $hWnd = WinGetHandle("[CLASS:TMainForm]") $iOld_Styles = _WinGetStyle($hWnd, 0) $iOld_ExStyles = _WinGetStyle($hWnd, 1) $iNew_Styles = BitAND($iOld_Styles, BitNOT($WS_SYSMENU), BitNOT($WS_CAPTION)) ;, BitNOT($WS_SIZEBOX)) _WinSetStyle($hWnd, $iNew_Styles, $iOld_ExStyles) WinMove("[CLASS:TMainForm]", "", -3, 265, 807, 273) WinMove("[CLASS:TMainForm]", "", -4, 266, 808, 274) Func _WinSetStyle($hWnd, $Style = -1, $ExStyle = 0) Local Const $GWL_STYLE = -16, $GWL_EXSTYLE = -20 Local Const $SWP_NOMOVE = 0x2, $SWP_NOSIZE = 0x1, $SWP_SHOWWINDOW = 0x40, $SWP_NOZORDER = 0x4 Local $iFlags = BitOR($SWP_SHOWWINDOW, $SWP_NOSIZE, $SWP_NOMOVE, $SWP_NOZORDER) If $Style = -1 Then $Style = BitOR($WS_MINIMIZEBOX, $WS_CAPTION, $WS_POPUP, $WS_SYSMENU) DllCall("User32.dll", "int", "SetWindowLong", "hwnd", $hWnd, "int", $GWL_STYLE, "int", $Style) DllCall("User32.dll", "int", "SetWindowLong", "hwnd", $hWnd, "int", $GWL_EXSTYLE, "int", $ExStyle) DllCall("User32.dll", "int", "SetWindowPos", "hwnd", $hWnd, "hwnd", 0, "int", 0, "int", 0, "int", 0, "int", 0, "int", $iFlags) EndFunc Func _WinGetStyle($hWnd, $iIndex=0) Local Const $GWL_STYLE = -16, $GWL_EXSTYLE = -20 Local $iGWL_Index = $GWL_STYLE If $iIndex > 0 Then $iGWL_Index = $GWL_EXSTYLE Local $aStyles = DllCall('User32.dll', 'long', 'GetWindowLong', 'hwnd', $hWnd, 'int', $iGWL_Index) Return $aStyles[0] EndFunc
closeOSK.au3
toggleOSK.au3Code:If WinExists("[CLASS:TMainForm]") Then WinClose("[CLASS:TMainForm]", "") EndIf
Edit: Updated code a little.Code:If WinExists("[CLASS:TMainForm]") Then WinClose("[CLASS:TMainForm]", "") If WinExists("Garmin Mobile PC") Then WinActivate("Garmin Mobile PC") EndIf Else Run("openOSK.exe") If WinExists("Garmin Mobile PC") Then WinActivate("Garmin Mobile PC") EndIf EndIf
my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
Ah that makes sense. Anyway, just tested it on my carPC (Win7 32bit) and it's working greatMuch better than the other overlay too since the OSK is transparent and you can see the street name results/etc better.
I found GMPC did disappear once but an advantage of the OSK toggle button is that it brings it back up again. Now I can reliably use GPS again after months of frustration when I actually did need to use it. Thanks for the tip ^_^
I guess one thing to improve is not having to move it twice to remove the title bar.
very good job...............thank you
In win 7 u can easy to use tablet pc input panel its perfect its can resize autohide easy to move always on top...etc
I test by use this command to call osk on skin "run;c:/programfiles/common files/microsoft shared/ink/taptip.exe"
I use freevk.exe because my carpc use winxp
I want to strete osk window to button Please....
Hmm try edit the FreeVK.ini, seems to have some height and width settings.
Yeh... I try Freevk.ini settings
But I cannot fix height and Its seem fix by autoit
if you are using the autoit scripts you will have to make the adjustment there.
I dont understand about autoit scripts
Anyone please help me
thank you
this particular autoit script is fairly simple and easy to modify. autoit is also free for you to download. just install autoit, open up the autoit script editor or your favorite text editor and copy and paste the code from above and create the separate files. find and modify the second winmove line to your liking. the four sets of numbers are x, y, width, height.
the file extension needs to be .au3. right click on each file and select compile. that should be it.
