Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Feeler - Dual Monitor Skin
  1. #11
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    I use on-board VGA and S-Vid set for extended desktop mode.
    -InfinitiPC
  2. #12
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    Same with me, just using the composite instead.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  3. #13
    Mar 2008
    Yeah I know... you just posted that -lol. I was responding to TreeTop
    Wait, you actually you use a LP card rather than on-board. Lier!
    -InfinitiPC
  4. #14
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by InfinitiPC View Post
    Do you have a write-up or worklog by any chance?
  5. #15
    Nov 2005
    Toronto, ON
    total truth. it's a low profile AGP so it does everything I need it to.
  6. #16
    Nov 2005
    Toronto, ON
    Alright, have a play guys.... link in the first post.
  7. #17
    Mar 2008
    Spawn: Thanks for the post. This will help me greatly in making my own skin.
    TreeTop: Nope, I don't even have a good install yet. For now my CarPC is just sitting behind my seat with wires running to the A/V in in the center console.
    All you need to know about dual screen is this: You need 2 outputs, VGA and Composite or S-Vid. They can be separate video cards or a single one with DualHead extended desktop. Most of the ITX boards do this. Go in to desktop properties, extend the desktop to the second monitor, and position the screens however you like. If you are using this skin the TS-VGA should be on top of the video out. You could make an RR skin that is 1600x480 and put the screens side by side, it really doesn't matter how you do it. To RR, you just have one big skin, it doesn't need to know anything about dual monitors.
    -InfinitiPC
  8. #18
    Nov 2005
    Toronto, ON
    FYI, mine was designed to run at 1024x1536, mostly for because of the dj program I use at shows. You should be able to change the resolution in the general.ini for lower resolutions.
  9. #19
    Sep 2006
    War-Town, GA.
    I see the skin is geared to dual monitors; unusable to me right now but i'm doing some research and might be able to use it later.
    Looks good from what i could see. Nice and simple.
    Thanks for sharing.
  10. #20
    Nov 2005
    Toronto, ON
    Actually as long as you can live without the extra track information, it will function perfectly as a single monitor skin as well. RR will just cut off the bottom screen.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Dual Audio... Again - The Chiken or the Egg?
    By Robert_IT in forum Newbie
    Last Post: 02-28-2008, 04:58 PM
  3. Intel Dual Video, Dual Audio motherboard
    By wicket in forum General Hardware Discussion
    Last Post: 10-23-2007, 08:36 AM
  4. Is there 184 pin dual channel DDR RAM?
    By Maheriano in forum General Hardware Discussion
    Last Post: 01-05-2007, 05:02 PM
