Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: My comprehensive guide to Road Runner and Flash
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by meddler View Post
    Sonicxtacy,
    This is a really good how to. I have made it a sticky.
    I will request that everyone not post in this thread to keep it clean for Sonicxtacy's guides.
    Thanks for the sticky. i wasnt sure how comments would/should be handled.. but i will continue to update the table of contents as tutorials are added so there is at least SOME organization
    EDIT
    i know i'm several months behind on this.. but its on my new years resolution list! For the wait i will also be including snippets on playlist searching.. all done within flash and lighting fast (faster than winamps JTF plugin!)
    Live mp3Car Facebook Chat
  2. #12
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Quote Originally Posted by Sonicxtacy02 View Post
    Chapter 1: Running Ride Runner Commands In Flash
    Due to the level of implementation in Ride Runner's source code, running a RR command inside a flash skin could not be easier. Flash uses the function fscommand() to send the command into RR's queue. For example, if u wanted to run the AUDIO command in your flash skin the correct syntax would be:
    Code:
    onSelfEvent (press) {
        fscommand("AUDIO")
    or
    Code:
    on(press) {
        fscommand("AUDIO")
    This code can be used on any flash object, whether it be a sprite, text object, or shape. ALL ride runner and custom commands (from exectbl.ini) can be run this very same way. Very simple right?
    Now there are ways within flash to change which command is run based on other events, variables, etc. More on this later
    I tried this coding with adobe flash cs3 and I always get an error. Is there any way the coding would be differant for this version? It works fine with swishmas???
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
  3. #13
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by rizaydog View Post
    i've never used adobe flash so i couldnt tell you. Definitely works in swishmax though. Whats the error you are getting
  4. #14
    Nov 2007
    North Central PA
    This is from the CS4 I have at work, but its the same error:
  5. #15
    Woodbridge, VA
    Blog Entries
    32
    cant see what that says
  6. #16
    Nov 2007
    North Central PA
    Heres a close up. Sorry
  7. #17
    Feb 2010
    Will this guide be finished?
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  3. Flash in Road Runner
    By MGD in forum Road Runner
    Last Post: 02-28-2007, 03:20 PM
  4. Microsoft Vista and Road Runner
    By skippy76 in forum Road Runner
    Last Post: 07-21-2006, 03:19 PM
  5. Replies: 0
    Last Post: 03-14-2005, 02:48 AM
