Results 1 to 7 of 7
Thread: Problem: random tracks
    Jan 2004
    Illinois
    I have burned nearly all of my cds myself, and have them numbered in order of play. For some reason, either RR or Winamp is now playing them out of order.
    Each folder has numbered names. I purchased tag and rename, and made sure that they all have track numbers as well. no change.
    On most cds the list is completely backwards. Last plays first etc.
    i have been back and forth to rename, manually renaming. and nothing seems to work.
    Folders = Artists Name\Album\#Track Name.mp3
    Any thoughts would be appreciated.
    Nov 2004
    St Louis
    Quote Originally Posted by Tzunami View Post
    Back to basics: what skin are you using, what version or RR do you have, what version of winamp, what does your RR.ini look like?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'd say the only thing that looks funny is the Winamp version 2.75???? best two are 2.95 or 5.13.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jan 2004
    Illinois
    I will give them a whirl. and sorry for not posting specs earlier.
    stupid of me,. Even I know better.
    Jan 2004
    Illinois
    Finally
    I got Winamp 2.85 no chanhe, and 5.13 .no changes
    tried several skins no change.
    So if no winamp, not rr then it must be my skin.
    But when going thru BMV2 I see that if i press the select key and not select + the order is fine.
    So I go to my command, substitute :Select for Add1, and it works perfectly.
    Thanks everyone for helpimg me work out the logic.
    And your right try other people skins. you might just learn somethin.
    Clif
    Jan 2004
    Illinois
    Ok i got it. it was tricky
    My orginal cmd was
    "CLEARLIST||Add1||PLAY||Back||Back||Load;Audio_Pla yer.skin;Music"
    Clearllst = ok Add1 not so good becase it adds the list in strnage ways
    Play = oK amd Back back to get out of the subfolder the load.
    Changed it to
    "CLEARLIST||!Select||Back||Back||PLAY||Load;Audio_ Player.skin;Music"
    !Select = ok and stays on same skin, then back baCK PLAY works on the album browser skin to reset to main dolder, the load player.
    Select wony work because it moves to you player skin, then back back play is not understood on the player and ignored.or worse play causes pause.
    While I did work it out nyself, thanks GizmoQ for pointing out the basics that i had forgotten.
    cliff
    Nov 2004
    St Louis
    cliff
    No Problem (NP)
  1. Random Reboot problem solving
    By overlander in forum WinNT Based
    Last Post: 07-14-2008, 01:51 PM
  2. DSATX problem, not power switch problem!
    By VThokieME in forum Power Supplies
    Last Post: 05-04-2008, 01:22 AM
  3. vb6 Help generating a random number
    By J187 in forum Coders Corner
    Last Post: 04-08-2006, 02:49 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. MPXPlay / MPXF ... random play
    By DaBretty in forum Software & Software Development
    Last Post: 07-20-2000, 10:32 PM
