Results 1 to 9 of 9
Thread: LSX Void Questions
    Jun 2008
    LSX Void Questions
    Few Questions regarding LSX Void that I can't find the answer to:
    1. How do I make the speed at the top display in mph instead of kmh?
    2. Is there a way like in digital fx to have a button in the audio section so that when I plug in say my ipod or a usb thumb drive I can select which source I want roadrunner to play from?
    3. In the video that was posted about this skin in the original LSX thread the person is browsing threw the music like if using an Ipod touch just click and drag the list up instead of hitting the arrows, how do I get this?
    4. Ok my music from where is from Rhapsody always has track number in front of it so it makes it impossible for me to browse music by A,B,C, how can I make it show up in artist view and go from there?
    and one last question that doesn't really pertain to LSX but what are you guys using to wirelessly(sp) sync your music from your home computer?
    Thanks!
    Jun 2008
    bump...
    Jun 2008
    bump
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    1. Try this
    2. Search
    3. Read Here and if you encounter problems read this
    4. Refer to #2
    Is This what you're asking about. (wireless sync) See Confusion Master, AKA Enforcer
    Hope this helps (all it took was a lil searching)
    If you cant DODGE em, RAM em.
    Jun 2008
    iList is not working? Not encountering like a problem, but I enable it and nothing changes.
    As for Number 4, I did search. When I look at my playlist in winamp it doesn't show the numbers just the artist. Why does RR do the oposite? I did find something about the mp3 tags not lining up but Im not sure what to do about that.
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Quote Originally Posted by mdawg View Post
    I think this is down to a setting in rr.ini ("Listnumbers=true") set it to false to remove the line numbers. I am sure this is an option in the config utility.
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Jun 2008
    Ok that should solve my problem but any suggestions on the Media problem other than using something like RRMedia Plugin?
    Jun 2008
    Oh Btw....the ilist still doesent work. Its turned on and Numbered Playlist is still checked yet it has not changed one bit.
    On another note I have tried everything on my music...htf do I make It just display my albums and go from there. I went in RR and changed the Format to %album% on both options and STILL it displays the song title...
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
