Results 1 to 7 of 7
Thread: Pass Plugin Command To Flash?
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Is this possible? I'm trying to make some gauges to display data from my obdmpg plugin and things don't seem to be working. I can successfully get flash to display a RR label such as "AUDIOTRACK" but any attempts at getting it to display something from my plugin, such as "obd_vss" haven't been working.
    Am I just missing something or is this not a function of RR?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    is the label defined in the .skin? Is the case correct? Does the label display in a non flash skin? Flash reads plugin labels the exact same way as standard labels
    Live mp3Car Facebook Chat
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    The label is defined in the skin, case is correct, and it does display the values fine in the skin just not in flash. Like I mentioned it works fine with the default RR commands, just not with those from my plugin.
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Just a little update on this problem. I found out that in order to get things to work correctly the case specified in the flash file had to be opposite that specified in the skin file/plugin. So if I define a label "obd_vss" in the skin file, creating a dynamic text box with "_root.OBD_VSS" works like a charm. If I match the case though I get nothing. This is exporting as a SWF8 in swish max.
    Woodbridge, VA
    Blog Entries
    32
    thats really odd. i've never seen that problem... but least ya figured it out!
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i think rr passes all the labels to flash in caps.. so it is not the opposite exactly
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Nomader View Post
    It didn't seem to work that way for me. If I changed the plugin command to all caps and made the flash commands in all caps it didn't work. If I switched the flash commands to lowercase it worked. Not sure why, all I know is that it works. The same behavior didn't exist for the default RR commands just those from my plugin.
  1. RRJTFE: Jump To File Extension Plugin (beta)
    By Sal R. in forum RR Plugins
    Last Post: 11-29-2010, 06:54 AM
  2. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  3. Flash Help sending a $var to RR
    By JohnWPB in forum Road Runner
    Last Post: 09-28-2007, 05:09 AM
  4. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  5. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
