I had made it so it will use meters if it gets "m" or feet if it gets "ft" in the GPSALT variable from Riderunner.
unit display for meters is x10, for feet is x100.
I assumed the value in ft comes without decimal value, if it does let me know and I will modify because it surley won't look ok.
Please test it in feet as I only tested in meters inside Riderunner.
Number display of the altitude is only in pure text field. I am afraid I won't make the fancy analog counter.
I also want to add a satelite nr. display info somewhere.
