Results 21 to 30 of 33
Thread: FLASH PROGRAMMER NEEDED: Flash Altimeter Guage
  1. #21
    Newbie tokragua's Avatar
    Oct 2009
    I had made it so it will use meters if it gets "m" or feet if it gets "ft" in the GPSALT variable from Riderunner.
    unit display for meters is x10, for feet is x100.
    I assumed the value in ft comes without decimal value, if it does let me know and I will modify because it surley won't look ok.
    Please test it in feet as I only tested in meters inside Riderunner.
    Number display of the altitude is only in pure text field. I am afraid I won't make the fancy analog counter.
    I also want to add a satelite nr. display info somewhere.
    Attached Files Attached Files
  2. #22
    Nov 2004
    St Louis
    Quote Originally Posted by tokragua View Post
    This looks perfect in my skins. Unfortunately, like you mentioned earlier, it does fall off fast when sats drop out. For some reason, its also jumping back and forth between meters and feet - probably because I have so many other timed scripts. Will do some more testing and pull my debug. Would changing the update rate smooth this out? i.e., update every 5 or 10 seconds?
    Beautiful work! Just a couple bugs to work out.
    Thanks for developing this for me.
    Giz
  3. #23
    Oct 2009
    Hi and thanks for testing.
    What does the GPSALT variable show when jumping from meters to feet ?
    This is how I test for meters (read_frame is the variable for gpsalt)
    I asume if it has m at the end it's meters, otherwise it's ft
    if (read_frame.charAt(read_frame.length-1)=='m')
    unit_type.text="meters";
    unit_nr.text="10";
    else
    unit_type.text="feet";
    unit_nr.text="100";
  4. #24
    Nov 2004
    St Louis
    After more testing and logging its not your program where the problem exists. Out of 5 tries, one was stable. Wasn't an issue with the flash; more like somewhere between RR and the GPS. I thing my GPS is going bad; will swap out the GPS puck this weekend and try again.
  5. #25
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi Guys can some 1 pls let me Know how do i ge this to work in Feet....instead of meters...
    Just like the iphone applications have the Feet function...
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  6. #26
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    Are you getting the white background with this gauge? For some reason I am getting the white background, which is strange, as white is the color that RR is supposed to make transparent....
    My Fiero Build Thread
  7. #27
    Oct 2009
    This got transparent for me, as I could see the main backround in a test skin I installed it.
  8. #28
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This is very nice and I agree with John, it needs to be in feet not meters.
    My only requests would be to put the digital counter on the gauge itself (say at the bottom in all that empty space, with room for 5 digits - yes I fly mine) and the barometric pressure readout just above that. Barometric pressure can be pulled from Ride Runner, too.
    Whenever you're ready to send me a copy, I'm ready to install it.
    I think that the good way is to have in metre and another in feet .
    RR is used by users around the world !!!!
  9. #29
    May 2008
    Bordeaux, France
    Smile
    I try this altimetre with an issu. I don't see it .
    I have that into my screen !
    Code:
    F,71,177,356,320,"altimetre.swf"
    Where is my error please !
  10. #30
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, after hearing others see it as transparent, I tried re0installing Flash. That did it for some reason. I just installed Flash 10 when I built and installed windows from scratch a few weeks ago. Also strange, is the other gauges, logo's and all other stuff in the skin was working correctly.... Strange. Never the less, it is working correctly now.
  1. Flash expert needed
    By Chuck in forum Road Runner
    Last Post: 02-07-2007, 12:52 PM
  2. Help needed w/ flash logos
    By titubatu in forum Road Runner
    Last Post: 12-11-2006, 01:29 PM
  3. help needed with flash Clock
    By Nomader in forum Road Runner
    Last Post: 06-26-2006, 05:07 PM
  4. Flash solution needed
    By netrider in forum Software FAQs, Solutions, Tutorials
    Last Post: 01-23-2006, 07:08 AM
  5. Open Call, Flash help needed for tracker !!!!
    By frodobaggins in forum Software & Software Development
    Last Post: 05-08-2005, 07:25 PM
