Page 21 of 26 FirstFirst ... 11121314151617181920212223242526 LastLast
Results 201 to 210 of 255
Thread: Skin Editor [ v0.7.8 Updated 4/17/11 ]
  1. #201
    Jun 2002
    Virginia
    Try v0.76d, post #1
    I am consistently getting "Run-time error '53' File not found" error with .76d and XP3.
  2. #202
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Default install? What/when..ie steps done when it occurs? I need to get out the bug spray for this one, just won't go away on its own....
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #203
    Jun 2002
    Virginia
    Yes, default install. RR 11/12/09 in c:\program files\Riderunner, DFX4 in c:\program files\Riderunner\Skins\DigitalFX 4.0, RRskineditor.exe in c:\program files\Riderunner. OS is XPSP3.
    There are no steps involved. I double click the exe, the error message appears and nothing happens.
  4. #204
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    i had this issue as well, you HAVE TO point the new 76d, IT TO SKINEDITOR FOLDER, copying over the old version. Then it will work
    Did it.. Done it... now I got to keep the neighbors kids away!!
  5. #205
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by kbreeden View Post
    Quote Originally Posted by jessekilner View Post
    Yes, that would be the issue....its supposed to be in the skineditor folder, not rr's root. I read your post earlier, tried to figure what as causing it..couldn't...reread post and then noticed that you said you had in root...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #206
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Is it possible to add a copy option with offset and number of item to copy.
    By exemple:
    ix,10,5 copy the selected item 5 time with a space=10 pixel (horizontally)
    iy,10,5 idem but vertically.
    Then it was easy to copy the same item any time with always the same space.
    And why not a command ix,10,5,400,200 where 400,200 is the posiion where the first item is copied .Idem for iy .
    I should like an option like that .
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hey Blue, did you get my PM about the bug I wanted to fix ? (it's bugging me hehe)
    Ride Runner RR's Myspace
  8. #208
    May 2005
    Hi Blue, would you be releasing a new version which supports the drop shadow effect for LABELS?
    L01,110,10,580,60,255,255,255,36,"Calibri:B","My Label","CENTER",,"DS=3,3,0,0,0"
    Currently the part in RED gets truncated off if I edited it with the skin editor.
  9. #209
    May 2008
    Bordeaux, France
    Quote Originally Posted by RS200Z View Post
    Currently the part is RED gets truncated off if I edited it with the skin editor.
    Very good idea in fact
  10. #210
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There is just soo much that needs to be done on the SE... I would also like to change the way it saves, being it only save the screens that you have actually changed verse all of them. This makes it easier when latter you try to recall if you have modified a screen but can't remember exactly which one(s) it was as it just saves all of them, so looking at the modified date does no good.
    But at current my 100% focus is on DFX5. So till then, I'll keep it noted and see if within the next two releases, I can get to these...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RockCar Front End v0.0.154 - Skin Editor Updates
    By Hessian in forum Software & Software Development
    Last Post: 11-21-2008, 11:40 PM
  2. error skin editor 0,5
    By ammerelli in forum RR Skins
    Last Post: 11-18-2007, 08:25 AM
  3. Error with skin editor
    By JDizzle in forum RR Skins
    Last Post: 06-13-2007, 01:47 AM
  4. CF Skin Editor RC1
    By djerik in forum CF Skins
    Last Post: 10-19-2006, 01:10 PM
  5. Road Runner Skin Editor
    By rikblacketer in forum Software & Software Development
    Last Post: 10-17-2006, 07:30 PM
