Page 24 of 27 FirstFirst ... 1415161718192021222324252627 LastLast
Results 231 to 240 of 263
Thread: Skin Editor [ v0.7.8 Updated 4/17/11 ]
  1. #231
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hi BlueZX3,
    Can you notify that the 0.78 version don't accept the new Indicator format !
    Thanks again for your job :-)
  2. #232
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya I'll take a look and get it updated
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #233
    May 2008
    Bordeaux, France
    Cool Blue, big thanks
  4. #234
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I put a updated object.txt in the first post, just replace with your current one found in the SkinEditor RR folder.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #235
    May 2008
    Bordeaux, France
    Cool, Big thanks again BlueZx3
  6. #236
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I've been struggling with an "Error: 75" Path/File access error for the past week. I've reloaded RR and tried an earlier version that known working. It only pops up when I try to launch the SkinEditor. I did have to do a system restore since this worked last. Windows XP Tablet (PRO) SP3. Any suggestions. Only this application has been a problem since the restore. RR runs fine.
  7. #237
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not sure, in the same folder that you have the skineditor, you should have at least: SkinEditor.exe, objects.txt, background.txt. Depending on setup, you also might have the settings file "settings.txt" there too, otherwise it should be in %APPDATA%\RRSkinEditor folder.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #238
    Apr 2009
    Davisburg, MI
    I have a background JPEG but not a .txt file. This is a fresh install from NISU May 20 with everything loading to default directories. Do you have this background.txt file handy?
  9. #239
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    There is not a Background.txt file anywhere in that folder. Blue just used the wrong extention for the background.
    There is only objects.txt, hystory.txt. background.jpeg and the exe.
  10. #240
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Opps...My bad.
    You can also now delete that gdipluswrapper.dll as that was before we updated the SE to use the newer one that rr is now using. What about the settings.txt file? I don't see it there, open the run dialog and paste %APPDATA%\RRSkinEditor and hit enter, should open up directly to that folder and there you should have your settings.txt file
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RockCar Front End v0.0.154 - Skin Editor Updates
    By Hessian in forum Software & Software Development
    Last Post: 11-21-2008, 11:40 PM
  2. error skin editor 0,5
    By ammerelli in forum RR Skins
    Last Post: 11-18-2007, 08:25 AM
  3. Error with skin editor
    By JDizzle in forum RR Skins
    Last Post: 06-13-2007, 01:47 AM
  4. CF Skin Editor RC1
    By djerik in forum CF Skins
    Last Post: 10-19-2006, 01:10 PM
  5. Road Runner Skin Editor
    By rikblacketer in forum Software & Software Development
    Last Post: 10-17-2006, 07:30 PM
