Page 26 of 27 FirstFirst ... 161718192021222324252627 LastLast
Results 251 to 260 of 263
Thread: Skin Editor [ v0.7.8 Updated 4/17/11 ]
  1. #251
    May 2011
    Carputer1
    Thanks for reply. I am just using images. I hoped I could just have 'play' icon on the OFF layer and 'pause' icon on the ON layer (I have done similar on radio skin with band button changing FM to DAB) I guess this is not that easy. The command on the play button is "PLAY". Can you point me to some reading material that may help me, I am new to this.
    It is supprising how once you start with RR you start to want to make it work your own way, its just a matter of how much time you are happy to spend on it.
    Jeff
  2. #252
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And for that Fact alone, is what RR is all about! Sorry, bit OT but...I can never pass up an opportunity to help show off why RR is the Caddy of FE's...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #253
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok if your want info ,, here it is ,,, i will not spoon feed you then lol...
    theres a label cmd "STATUS" this shows the value of what play is doing ,, ie stop , pause,play
    blue & john made a nice test app called skintool , you can use that to see the value of status ,, just put the cmd in the box select label and check auto update
    then just hit play in you skin you will see the change
    now i suggest look through skin cmds.txt in your docs' folder and history.txt look for how to use
    setvarbycode for thet status cmd ,,,,, then you can use a indicator useing byvarx with the images you want to use
    if you are still stuck and want more help shout
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #254
    May 2011
    Pause in Simplistic
    Thanks Carputer1, I have that working now. Next on desire list is to display Vol% only when (and for a few seconds after) adjusting volume. Is this possible? or, is this possible for a mere mortal to achieve?
    Thanks again
    Jeff
  5. #255
    Nov 2010
    I get this error every time I create a new skin. Is there something wrong with my computer that is making the editor not operate properly? Looking Forward to your reply.
    LHLXD
  6. #256
    Jan 2013
    Quote Originally Posted by LHLXD View Post
    LHLXD
    I don't think your computer is the problem, I am having this same issue on two different systems.
  7. #257
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by jeffhills View Post
    Carputer1
    Jeff
    I designed a play pause button for DFX and I figure if I shared it with DFX I can share it with you. I made a custom font with the play and pause. The y in play as the triangle play icon and the e in pause as the double line pause icon.The status, actually shows the words play and pause, but since the letters of the y and e are the play and pause icons and then right justified in the button, with an appropriately sized label window in the box, you only see those icons.
    I tried this with images, but it just wouldn't work. I also tried a toggle command with images, but toggle has no relation to what the actual play, pause status is.
    Here is my original post from way back in DFX 4
    So I remembered a while ago someone asked about making the play button display when paused or stopped. Well I finally had a minute to use the suggested solutions, and thought I would post the results. It is done with a font, so it takes the skin color and needs no art work changes.
    Drew is the name of the font included. Unzip the file and place the font in C:/Windows/Fonts.
    It is right justified in the label so the Y becomes the play, the E becomes pause, and the P becomes the stop. Obviously you may need to adjust the alignment on your play button.
    This line needs to replace the red line below in the bottombuttons.txt in the skin folder.
    L4,334,539,45,65,#DFX1R#,#DFX1G#,#DFX1B#,23,"Drew" ,"Status","Right"
    INC,DFX_Font_Color.txt
    L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"DFXFon t1","=2","CENTER" Replace this line here.
    L,628,531,71,67,#DFX1R#,#DFX1G#,#DFX1B#,29,"Arial Black","=+","CENTER"
    L,526,516,71,67,#DFX1R#,#DFX1G#,#DFX1B#,40,"Arial Black","=-","CENTER"
    L,712,502,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER"
    L,599,504,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER"
    L,509,502,57,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER"
    L,412,498,71,67,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFon t1","=3","CENTER"
    L,213,508,71,67,#DFX1R#,#DFX1G#,#DFX1B#,60,"DFXFon t1","=1","CENTER"
    L,8,542,83,36,#DFX1R#,#DFX1G#,#DFX1B#,24,"Larabief ont:B","=MENU","CENTER"
    L,114,507,71,65,#DFX1R#,#DFX1G#,#DFX1B#,60,"DFXFon t1","=0","CENTER"
    Revised to show Play when paused or stopped, and Pause while playing. Function rather than status.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  8. #258
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Found an issue with skintool and the new options of CUSTOM LIST that are deleted !!!
    example:
    SC01,294,160,400,420,255,255,255,0,0,0,64,64,64,25 5,255,255,TRUE,20,"Arial Narrow:B",00,"","WEBRADIO_SETURL;$LISTTEXT$;$LISTDESC$",""
    example:
    SC01,294,160,400,420,255,255,255,0,0,0,64,64,64,25 5,255,255,TRUE,20,"Arial Narrow:B",00,"","","WEBRADIO_SETURL;$LISTTEXT$;$LISTDESC$"
    Thanks your your fix !
  9. #259
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    I am new to skinning. How do I use the skin editor???
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  10. #260
    MySQL Error
    Oct 2004
    pierrotm777, im not sure if this is really an active project
    unless someone wants to take it over (skin editor that is)
    id love for a complete new one, but thats prob not worth it
    but for your issue, i think u can just edit a text file
    skin editor is really out of date
    i use text editor
    i know... i know...
    look in objects.txt, mess with that
    /, (SC) Custom List
    Custom List,SC,x,y,w,h,forecolor R;RGB,G,B,backcolor R;RGB,G,B,selected color R;RGB,G,B,select color R;RGB,G,B,trs,font size;FONT,font name
    maybe add fileds
    /, (SC) Custom List
    Custom List,SC,x,y,w,h,forecolor R;RGB,G,B,backcolor R;RGB,G,B,selected color R;RGB,G,B,select color R;RGB,G,B,trs,font size;FONT,font name,something1,something2,something3
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. RockCar Front End v0.0.154 - Skin Editor Updates
    By Hessian in forum Software & Software Development
    Last Post: 11-21-2008, 10:40 PM
  2. error skin editor 0,5
    By ammerelli in forum RR Skins
    Last Post: 11-18-2007, 07:25 AM
  3. Error with skin editor
    By JDizzle in forum RR Skins
    Last Post: 06-13-2007, 12:47 AM
  4. CF Skin Editor RC1
    By djerik in forum CF Skins
    Last Post: 10-19-2006, 12:10 PM
  5. Road Runner Skin Editor
    By rikblacketer in forum Software & Software Development
    Last Post: 10-17-2006, 06:30 PM
