That is V.5!! make sure you don't have it on cache or something -- check the window title for the version.
Hi!
I found this link: http://www.kompassist.co.uk/RRSkinEditor.zip
this is the V0.3019
where can i download the new version?
Englishlessness :(
Ride Runner RR's Myspace
Yes, but it drop me an error
ActiveX component can't create an object...
Englishlessness :(
Ok
it works, some missing Dll and OCX
THX
Englishlessness :(
hI ALL
fantastic job on RR
i had thought about building a car years ago but here in new zealand pc and parts arnt cheap, anyways i have now got one in my car for about 6 mths, nothing flash
but im making my own skin now and just downloaded this skin ed, i like the idea or a virtaul editor, loaded up my skin and hit the VE tab and get popup window with run time error '339" and RICHTX32.OCX error
any ideas?
ta
FUBAR
EDIT
got it working
http://www-1.ibm.com/support/docview...id=swg21171121
Hello all,
I am trying to use the new skin editor but i am getting a runtime error 339
component 'ComDlg32.ocx or one of its dependencies is not correctly registered: a file is missing or invalid. can anyone help with this. I have loaded the vb runtime file but still am unable to get the skin editor to work. thank you in advance for your help.
Seen that before. Download only that file (plug it in google); copy it to c:\windows\system32 then register it manually. The problem will be fixed.
the post above yours is same error
this fixed worked and havnt had any problems
problem resolved copied OCX files to system32 directory and all is well. thanks for the help.
I have just found another bug..
When saving the skin, it does not put a blank line under any INC lines or at least the last one. I was editing the DFX 3.0 skin and couldn't figure out why my plugin wasn't getting initialized.
Origanal skin file(top few lines):
To fix it I had to manually edit the skin file to add a blank line for rr to read it correctly.Code:RoadRunner Skin RRScreen menu. menu_OFF.png,menu_OFF.png,menu_ON.png,menu_OFF.png INC,DFX_Font_Color.txt INC,Plugins.txt L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","TEMP2","left" L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:","right"
Saved skin file, the one that doesn't work:
Manually fixed file looks like below, and now works again.Code:RoadRunner Skin RRScreen menu. menu_OFF.png,menu_OFF.png,menu_ON.png,menu_OFF.png INC,DFX_Font_Color.txt INC,Plugins.txt L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","TEMP2","left" L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:","right"
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
