Updated v0.7.7 (by Blue ZX3)
Added Italic font property Label support
Updated v0.7.7 (by mitchjs)
Fixed DropShadow Label support.
Fixed the lost "FORMAT" fild for labels
For versions .2 to .76h see the history.txt in the folder
Printable View
this sounds sweet!
Is it just the download for the skin editor?
For now, yes.. I'm still debugging on a few things in RR.
OUTSTANDING! Thanks :dance:
you did it again guino, thanks a million!!.
New version -- Thread updated.
:confused: I must have downed the wrong file :confused: There is no FILE>CREATE; FILE>EXIT; i don't see any option to load/edit/save... :confused:
There's no File->Exit, that is easily added (but you can close it using the RED X on the top right)..
To create a brand new screen: Click File->Open, hit "Make New Folder", name it, hit OK -- it will ask you to create a blank general.ini file, say YES, then from the Screen menu, click create new screen as many times as needed.
Guino, the source you have is quite a bit older. pRoFiT added a lot of nice stuff to the skin editor. He said he is sending me the latest source in email. As soon as I get it it, I will forward to you.
Since the version you are working with, he added the ability to move the buttons and labels using your mouse (Version posted above, you can not move or resize the objects with your mouse on the screen), it has an Undo Feature, as well as a "Virtual Editor" to view the skin in text format. Lastly it has a way to lock objects on the screen, so you can edit something behind something else Like a label on a button, many times you cant get to to the label to edit it, as the button is on top of it. You can lock the button, then are able to edit the label).
Well, I worked with what I had in hands.. if I get his version, I'll merge my changes to it..
