Results 1 to 6 of 6
Thread: Directory List navagation questions
    Apr 2007
    2 questions.
    1 - Is it possible to tell road runner to goto a specific screen after double clicking a item in a music directory list, instead of going back to the main menu?
    2 - How do you tell the directly list to scroll during a page up and down button command instead of simply popping to the next page?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Sure, place this in exectbl.ini:
    "SELECT","!SELECT||LOAD;MYSCREEN.SKIN",audio_brows er.skin
    2-I believe you want an iList instead of a regular list. You can make an iList (Smooth scroll list) by using the IL definition -- look it up in skin commands.txt. Many skins offer this by default, if you think the skin you're using has iLists, you should check that you have usedx=true in RR.INI.
    Ride Runner RR's Myspace
    Apr 2007
    Thanks for the help
    One more question to follow up on it.
    The audio script line you suggested worked perfectly.
    With the carwings skin, when you select a video from the list, it starts playing the video directly
    However i've tried doing it to my skin, and i can't get it to do it.
    I've also tried using this line in the exectbl.ini file
    "SELECT","!SELECT||LOAD;VIDEO",video_browser.s kin
    and also
    "SELECT","!SELECT||LOAD;video_player.skin",video_b rowser.skin
    those didnt work either.
    any ideas?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's no way currently to select a new video to play in the video browser without immediately playing it.
    This command is likely working, however that's exactly what the select code does in video, so you should have no visible effect...
    Code:
    "SELECT","!SELECT||LOAD;video_player.skin",video_browser.skin
    Apr 2007
    The result im getting is kinda strange...
    When i double click a video in the browser, it goes to the video player screen, but then the screen goes black.
    Upon pressing escape, the video starts playing in winamp off screen from the beginning????
    I thought that media player classic was supposed to play videos, perhaps i need to specify which app in windows plays them.
    But why would it start playing upon quitting the video player screen?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you may want to make a debug log and see what exactly it's executing.. in any case, you should at least say WHAT you're attempting to do exactly because the command "!SELECT||LOAD;video_player.skin" should be exactly what "SELECT" does (BY DEFAULT) if you don't have anything setup in exectbl.ini -- so why would you want to override it?
  1. Hardware Compatibility List - 800x480 Video Cards
    By alfabob in forum LCD/Display
    Last Post: 10-10-2006, 09:54 PM
  2. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  3. Replies: 1
    Last Post: 12-14-2004, 12:55 AM
  4. Focus toggle between 'Directory' and Playlist?
    By MegatronUK in forum FrodoPlayer
    Last Post: 11-18-2004, 10:53 AM
  5. Browse by directory
    By nappyjim in forum FrodoPlayer
    Last Post: 10-24-2004, 05:02 PM
