Results 1 to 5 of 5
Thread: LSX 3.3 - commands language dependence?
    Dec 2008
    I have setup the LSX in Chinese XP. All the buttons using NON-standard command will not work (for exmple, MAINBT1). It will be ok when I set the 'Language for non-unicode programs' to English. So, the command is language dependence? How to fix it, Pls help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Please add debugmode=true to RR.INI, run it, press some of those buttons and post a ZIP of your debug.txt file.
    Meanwhile, please provide also the following information:
    -Did you edit any ini files with a text editor ? if so, I'd suggest you use something standard like notepad to open/re-save the ini files.
    -How are you setting the code to be executed on MAINBT1 ?
    Ride Runner RR's Myspace
    Dec 2008
    Hello guino,
    Thanks for your response.
    I have not edited any file and have try to re-install several times. This time I try the 'EXT' (MAINBT7), but nothing happen. Debug file showed the following info. Full zip file can be download at http://www.turboupload.com/files/get...2CI0/debug.zip
    Enter Exec: False, menu.skin, "ONBTNPRESS||MAINBT7", False
    Que Exec: True, menu.skin, "ONBTNPRESS||MAINBT7", False
    Executing: ONBTNPRESS
    Que Exec: True, menu.skin, "MAINBT7", False
    Executing: MAINBT7
    Leave Exec: False, menu.skin, MAINBT7, False
    SDK command: REQUEST;milage;GPSLAT||REQUEST;milage;GPSLON||REQU EST;milage;GPSSPD
    Dec 2008
    The problem was fixed. It is the incorrect char in exectbl.ini. Now it runs smoothly. Thank you, guino.
    Sep 2008
    efun
    Can you tell me what exactly you changed in exectbl file?
    I have the same issue, I have to set launguage to English to make all buttons work except play/rwd/fwd, but then I loose asian song name corrupted.
  1. Replies: 44
    Last Post: 05-22-2009, 01:51 PM
  2. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-22-2006, 11:12 PM
