Results 11 to 20 of 30
Thread: png Clock Digits
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    make a colon image and i'll put together a quick .swf for you griff. Might as well add a "AM" image and "PM" image too. All the .swf will do is split the TIME label and use the images in the "clock" folder as numbers.. preserving transparency of course. Doing it this way still leaves it fully customizable because you can just change out the images. The Swf will also preserve RR's clock setting format.
    Live mp3Car Facebook Chat
  2. #12
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Thanks both.
    Sonic to my rescue again,Thanks mate.
    The images i've posted were just an example but i have the real images here...
    Should i make them the size i want them in the skin or will the swf scale?
    Is it possible to include a background? I think that would be better than a colon if you get what i mean ie.. if you wanted a standard colon you just create a png the size of the background with a colon on it but gives a lot of other configs.
    Attached Files Attached Files
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  3. #13
    Woodbridge, VA
    Blog Entries
    43
    got the files.. can do.. may even be able to "flip" the numbers ala that style of clock. I'll post something in the morning.
    Quote Originally Posted by Griff1 View Post
    Thanks both.
  4. #14
    Woodbridge, VA
    Blog Entries
    43
    havent forgot about you griff.. I forgot the auditor was scheduled to come in today.
  5. #15
    Nov 2005
    Midlands
    No problem Sonic,take your time,i know you'll get to it.
  6. #16
    Woodbridge, VA
    Blog Entries
    43
    something to this effect?
    Where would you like the am/pm images?
  7. #17
    Nov 2005
    Midlands
    Nice work,is it scalable? Are the images too small?
    Well the am/pm is only needed for a 12 hour display so would go next to the bottom of the 1 if in use.
    I've made a quick mock up of what i'm hoping to do,let me know if you need bigger images to work with.
    EDIT: Updated Mock Image
  8. #18
    Woodbridge, VA
    Blog Entries
    43
    yes its scalable.. looks good as long as you keep the H/W ratio consistent. Can you use Paint on that image to show me exactly where uwant the am/pm to go?
  9. #19
    Nov 2005
    Midlands
    How are you getting on mate?
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Been having a play and have come up with a mini plugin.
    It's called RRImageLabel.
    What it does is takes a character from an RRlabel and the displays an image of the users choice.
    So in the example below, the white background for the clock has been put on the empty image of the skin, but the numbers are dome from png files supplied by griff. For the time label which is 4 characters it takes four indicator lines to produce.
    Obviously it won't have the fancy flash step through when an image change happens, but hey.
  1. Clock loosing time - Infill G4
    By DAE51D in forum StreetDeck Bug Reports
    Last Post: 01-13-2009, 11:45 AM
  2. No GPS data with MPH CSC flash clock
    By crooper in forum Road Runner
    Last Post: 04-13-2007, 04:52 PM
  3. Replace logo with clock?
    By DaveB in forum Mobile Impact
    Last Post: 10-07-2006, 02:21 AM
  4. Powering LCD that has a clock
    By sedgett in forum LCD/Display
    Last Post: 03-17-2005, 11:28 AM
  5. Analog Clock possible?
    By mpfjr in forum Road Runner
    Last Post: 03-13-2005, 10:27 AM
